Old 03-17-2017, 10:28 AM   #1
topeltruckcenter
looking for parts
Im working on a 59 Chevy 3600 3/4 ton 4WD and I'm wondering if some on makes an adjustable drag link assembly and where I could find one along with lift kits for it, or at least just blocks and shims. Any help would be much appreciated. Thanks
topeltruckcenter is offline   Reply With Quote
Old 03-17-2017, 05:12 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: looking for parts
If your doing a specialized build then do a google on "drag link sleeve" and then find the ends you need. Its going to be the same for lift kits if its NAPCO, you may well find some generic blocks at a site like www.4wheelparts.com
dwcsr is offline   Reply With Quote
Old 03-17-2017, 11:16 PM   #3
nvrdone
I had an adjustable drag link made at a local 4x4 shop. just needed the tie rod ends and measurements. they did the whole job for about 50.00
nvrdone is offline   Reply With Quote
Old 03-18-2017, 01:57 AM   #4
mr48chev
mr48chev's Avatar
blocks the right width will work as lift blocks. Most 4x4 shops probably won't have the right width blocks unless the fit early Jeeps. U bolts you can get at the local 4x4 supply house or an O'Reilly's with a speed section or online. Other sources too but those are the simple
On that one I think your best option is to have the center made at a local machine shop and use the correct size tie rod ends to go with it. That may mean that you will end up using two right hand thread ends and have to remove one end to make the adjustment in length but making that adjustment should be a one time deal so that isn't all that big of a hassle even though having left and right hand threads so you can just turn the sleeve to adjust it is really nice to be able to
If you can't fix it with a hammer, you have an electrical problem.
My ongoing truck projects:
Old 03-18-2017, 01:59 PM   #5
1project2many
50's Dodge trucks also came with narrow lift blocks that might work.
1project2many is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
