01-26-2018, 04:33 PM | #1 |
64 C10 Power Steering
I know know that I would have done more research before buying components if I had to do it over. That being said I have an 81 power steering box mounted to the 64 frame and an 84 454 with hydroboost power steering pump. What hoses do I need to tie the pump to the gearbox not installing the hydroboost breaks. Need a high pressure hose with two ends one with long 90 to clear the frame and the low pressure return. Motor is already in with the pump and reservoir.
01-27-2018, 12:29 AM | #2 |
60-66 Nut
Re: 64 C10 Power Steering
If you are still running the long water pump, I would look at a hose for an '84 C20 with a 454 and see if that may work. That should have been available with a vacuum booster. If you had the hydroboost unit, you can always run that too. You would just need my hydroboost mounting plate to mount it to the booster bracket..
