Old 09-05-2021, 08:28 PM   #1
44SAA
R12 Vacuum
Started to pull vacuum on my OEM R12 system and noticed the valve on the high side is a smaller diameter than the low side valve. As a result my R12 dual gage canít fit on the high side valve. Can I just pull vacuum using the low side only? Thank you
44SAA is offline   Reply With Quote
Old 09-05-2021, 08:37 PM   #2
Ziegelsteinfaust
Re: R12 Vacuum
Yes it is just not as fast.
Ziegelsteinfaust is offline   Reply With Quote
Old 09-06-2021, 08:23 AM   #3
Katrina/10
Katrina/10's Avatar
Re: R12 Vacuum
You'll need a high-side adapter to use both gauges. They are still available.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 09-06-2021, 12:27 PM   #4
44SAA
Re: R12 Vacuum
While the threads on my yellow jacket R12 gauge fit on the low side- the schraeder valve on the low side isnít being depressed by the valve on gauge set. Katrina- is this the adapter you are speaking of. Kinda frustrated as I bough the yellow jacket gauge set labeled R12 as I figured it would hook right up? Thank you
Old 09-06-2021, 01:04 PM   #5
Katrina/10
Katrina/10's Avatar
Re: R12 Vacuum
The high side adapter looks like this: https://www.ebay.com/itm/153812368295
You attach it to the evaporator inlet then screw on your yellow jacket hose.
If you get no pressure reading on the gauge, there is something wrong with the valve or hose. Or, no refrigerant.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 09-06-2021, 02:32 PM   #6
Just call me Sean
Just call me Sean's Avatar
Re: R12 Vacuum
The blue line hooks there. Looks like you have the yellow in your hand.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 09-06-2021, 06:03 PM   #7
Corts60
Just here to tinker
Corts60's Avatar
Re: R12 Vacuum
Yep. Yellow one goes to the vacuum pump. Are you using a micron gauge to tell how far down you are pulling the system?
Old 09-06-2021, 06:15 PM   #8
44SAA
Re: R12 Vacuum
Thank you. I realize the yellow hooks up to the vacuum pump and the blue to low side. I just posted that pic to show the fitting that will not engage the schraeder valve as it is identical to the blue hose fitting. Thank y’all for the help. It’s been frustrating.
Old 09-06-2021, 06:26 PM   #9
44SAA
Re: R12 Vacuum
Hey Corts- not sure what a micron gauge is. I posted a picture of the gauge I am attempting to use. Thanks
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
