Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 07-30-2018, 04:24 PM   #401
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: Power Brake Booster Adapter Bracket
Send me a pm 61 suburban
Sick5 is offline   Reply With Quote
Old 07-30-2018, 11:17 PM   #402
Captainfab
60-66 Nut
I assume GM went with the bellcrank assembly to change the pedal ratio to one better suited to power brakes.
Yes you will have to remove the bolts attaching the pedal bracket to the firewall since my booster brackets use all of those attachment points just as GM designed it to be. This is a very important criteria that many people overlook or don't seem to care about. Automotive brakes is not a place to cut corners.
If you connect the pushrod to the original manual brake pushrod hole in your brake pedal arm, your brakes may be touchy. If so, just drill another hole in the brake pedal arm 1" lower and try that.
Originally Posted by First c10 View Post
Hey John,
I have a few questions.
First, What is the reason GM used the longer bracket with the pivot or linkage?
Second, To use your bracket I will need to remove the bolts that go through the brake pedal assembly that go through the fire wall?
Third, How does the direct push rod to the brake pedal affect the braking or the feel when braking?
Thanks Scott
Old 08-18-2018, 07:31 PM   #403
pdxhall
pdxhall's Avatar
John, I received my bracket today. Beautiful part. Thanks again
Brett
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 08-19-2018, 12:49 AM   #404
Captainfab
60-66 Nut
Thanks for the compliment and the purchase Brett
Old 09-08-2018, 10:47 PM   #405
CousinTone
John, just sent PM. Itís going on my 64. Brake Booster only in BLACK. Thanks, Tony
CousinTone is offline   Reply With Quote
Old 09-08-2018, 11:47 PM   #406
Captainfab
60-66 Nut
PM received as well as payment. I replied to your PM.
Old 10-02-2018, 01:21 AM   #407
chevyfreek
chevyfreek's Avatar
Hello, Going to the junkyard to gather the rest of my parts for my 65 C20 disk brake swap from a 78 C20. Will the booster and master cylinder work with your bracket? Or should I get a 88-98 1/2T booster and use the 78 master cylinder. Thank you for all the help you provide to everyone!!
65 C20 "Marilyn"
65 VW Bug "Daisy"
95 4Runner "JoJo"
15 Tacoma "Taco"
Check out my Intsagram https://www.instagram.com/patpetrey/
chevyfreek is offline   Reply With Quote
Old 10-02-2018, 11:29 PM   #408
Captainfab
60-66 Nut
None of the '73-'87 boosters are compatible with any of my booster brackets. They have the factory mounting brackets welded to them. That is why they are not on the list of compatible boosters. Yes you can use your '78 master cylinder as long as you use a booster that has the same length intermediate pushrod as the '78 booster. It should be the short one, but I would suggest checking.
Old 11-08-2018, 04:26 PM   #409
Reata
Captain Fab,
I sent you a PM as well and I need to get a bracket ordered ASAP. Can you reply and give me a call if you have a minute please.
Thanks very much!
Reata is offline   Reply With Quote
Old 11-09-2018, 12:34 AM   #410
Captainfab
60-66 Nut
I replied to your PM. I have time to be here on the forum only once a day after I get home from my 11-12 hour workday.
Originally Posted by Reata View Post
Captain Fab,
Thanks very much!
Old 12-08-2018, 06:08 PM   #411
preciador6
Captinfab what can I use for my 1963 P10 step van I need a power booster but I have no room or a hood.
preciador6 is offline   Reply With Quote
Old 12-09-2018, 12:26 AM   #412
Captainfab
60-66 Nut
I am not that familiar with the P series vans' firewall. Can you post a pic either here or email to captainfab454@hotmail.com ? You might be able to use a booster and master from either an Astro/Safari or full size G series van.
Old 12-09-2018, 12:39 AM   #413
preciador6
pics
Old 12-09-2018, 12:44 AM   #414
Captainfab
60-66 Nut
Well for starters, that has the hydraulic clutch as the '60-'62 Chevy's and '60-'63 GMC's do. So you would need my '60-'62 booster bracket to start with. Is that some sort of brace I see directly in front of the master cylinder? There are a couple of P series vans here on the forum in the '60-'66 projects and builds section. I do not remember what they used for a booster/master assembly
Old 12-09-2018, 12:53 AM   #415
preciador6
Yes i will have to move the brace to the side,I wont be needing the hydraulic clutch as i am goin automatic...seen this set up but i dont have a hood on on my 63.
Old 12-09-2018, 12:57 AM   #416
Captainfab
60-66 Nut
I make the '60-'62 booster brackets for use with an auto trans. Here is that for sale thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=357542
Here is one of the build threads that I was talking about.
http://www.67-72chevytrucks.com/vboa...ighlight=P+van
Old 12-18-2018, 01:36 PM   #417
bowties11
I will take one
bowties11 is offline   Reply With Quote
Old 12-19-2018, 12:38 AM   #418
Captainfab
60-66 Nut
I will send you a PM.
Originally Posted by bowties11 View Post
I will take one
Old 12-22-2018, 01:04 AM   #419
Captainfab
60-66 Nut
bowties11 your PM inbox is full and I can not reply to your PM's
Old 05-03-2019, 04:41 PM   #420
EricU
Junior Member
Hey Captain,
I am kinda new to this site. I just picked up a 63 Suburban.
I will be installing front and rear Wilwood disks on a new chassis along with a Caddy 472/TH400 combo to replace the stock 6 cylinder.
Attached is a photo of my current firewall/MC, I just want to verify that I am ordering the correct MC adapter of yours.
Also, do I just PayPal you for it? I apologize if you have all this info in this thread, but I'm going through 17 pages and trying to work!!!
* And one more "Also" - Do I need to lengthen the pushrod for the install?
EDIT: I just saw your email address and sent you an email also.
Thanks for your time, Eric.
Sent by the random thoughts from the voices in my head...
EricU is offline   Reply With Quote
Old 05-03-2019, 11:07 PM   #421
Captainfab
60-66 Nut
I replied to your email, payment received. Thank you
Old 09-11-2019, 10:53 PM   #422
gopackamx
I'm needing a pb mount and a couple of ps brackets for a 65
gopackamx is offline   Reply With Quote
Old 09-11-2019, 11:13 PM   #423
Captainfab
60-66 Nut
I'll send you a PM with ordering and payment info.
Old 09-14-2019, 12:22 AM   #424
racingdewman
racingdewman's Avatar
i purchased a CPP booster and master cylinder combo for my 64 c10 full disk conversion. what bracket option will i need and do you have any current picture of bracket? Price also.
racingdewman is offline   Reply With Quote
Old 09-14-2019, 12:36 AM   #425
Captainfab
60-66 Nut
Here are a couple pics that are more up to date than in post #1. The price is Exactly the same as in post #1. The only options available are satin black powder coating or if you need the hydraulic clutch conversion.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
