Old 10-13-2018, 01:13 PM   #1
72LB
72LB's Avatar
Did I mess up?
The harmonic balancer on my 350 is in rough shape and needs to be replaced. Not being near the truck I ordered one from memory (so I thought ). The one I got is 6 3/4" and the one on my 350 is 8", will it still be ok to run or should i get another 8"?
1985 C10 shortbed, current project.
Member of the Upstate SC GM Truck Club.
72LB is offline   Reply With Quote
Old 10-13-2018, 01:38 PM   #2
sweetk30
sweetk30's Avatar
Re: Did I mess up?
prob be fine but timming tab might not line up . but i have never ran in to this my self so i cant say for sure .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-13-2018, 11:46 PM   #3
Captainfab
60-66 Nut
Re: Did I mess up?
I would get the correct 8" balancer.
Old 10-14-2018, 03:21 PM   #4
61K10
61K10's Avatar
Re: Did I mess up?
either one is fine. there is two different timing tab's that bolt on. I have the smaller one on my crate 350 as the 8" would not fit with my front engine horseshoe mount.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-14-2018, 04:51 PM   #5
72LB
72LB's Avatar
Re: Did I mess up?
I was given a tab for a smaller balancer and was told most cars had the smaller one on them. Problem is I'll have to cut off the existing tab.
Old 10-14-2018, 07:10 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Re: Did I mess up?
Before cutting your tab, see if you can pick up a timing tape for your h-balancer. Some auto parts stores carry them or you can order on the internet. Just make sure #1 piston is at exactly top dead center on compression stroke and line up the tape TDC to the timing tab.
https://www.speedwaymotors.com/Mr-Ga...cer,30749.html
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-14-2018, 09:47 PM   #7
72LB
72LB's Avatar
Re: Did I mess up?
Hadn't thought about that, thanks for the tip.
