09-05-2017, 11:23 PM | #726 |
Re: 1956 Chevy Pro-Street Build
Truck is going to be awesome ptc!!! It has great history that video will be amazing. Good luck helping out in Texas I can't imagine what it would be like to be there.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
09-06-2017, 03:24 PM | #727 | |
Houston is doing well, these Texans are great people and the brisket down here is A-#1!!!! Love my BBQ! Lots of damage, but its all fixable.... and with IRMA coming soon its gonna be another big hit to the east. The US is taking it from all sides right now, we just gotta come together and be strong and helpful to one another!
My Build: 57 Chevy Pro-Street |
09-06-2017, 03:26 PM | #728 | |
Texas? --- it be like HUMID! --- right now in Houston.
09-07-2017, 02:45 AM | #729 |
ptc
good on ya!!!! NC
Been there, wrecked that |
09-09-2017, 08:59 PM | #730 |
Got home late last night from TEJAS! --- And have all weekend to try and get this thing started up and running. Got all the electrical checked out today and everything works EXCEPT the RFID PUSH/START button.... !!!!
Everything seems to be wired right, I programmed the RFID loop with the fobs and it accepts them, the unit has power and everything but the start sw doesnt work. I can bypass it and it works thru the start relay and all but just not thru the switch. So I sent an email to CHINA! ---- We'll see what I get back! If anybody is an engineer of these things I can send you the diagrams ---- Got all the fluids filled up. The oil temp sender is in the drain plug for now, the pan didn't have any other bungs to use.... Really???? Im ready to drive my mailtruck! ---(No doors)
My Build: 57 Chevy Pro-Street Last edited by ptc; 09-17-2019 at 08:50 AM. |
09-09-2017, 11:18 PM | #732 |
Sweeet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-10-2017, 01:39 AM | #733 |
Well your plate does say KRZY, so bound to have a few challenges.
Sure looks good though. Mudman.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
09-10-2017, 05:29 AM | #734 |
Truck is looking great!!
You get it all to work right, you'll see Much respect PTC, for helping out in Texas!!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
09-10-2017, 10:20 AM | #735 |
Looking good!
Jim |
09-10-2017, 10:39 AM | #736 |
Thanks for the comments all! ---- Still working it!
Kees -- you coming to America anytime soon???? Need some pinstriping done!
09-10-2017, 02:56 PM | #737 | |
Ho Lee Chit, SO Solly! (Sorry for the racially insensitive humor. Couldn't pass up the opportunity! Apologies to any of our Asian members. I'm Hispanic and I TRY to be of good humor about stereotypes.)
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
09-11-2017, 12:21 AM | #738 | |
Got lots of mexican jokes! --- is mexican a racially insensitive word too? Actually I got a response - he has a bunch of videos on UTUBE --- heres one he sent me for wiring.... anybody understand jibberish!!!! --- lol kidding!!!! I know its chinenglish! https://www.youtube.com/watch?v=CEac_1_mIQ4
My Build: 57 Chevy Pro-Street Last edited by ptc; 09-11-2017 at 01:02 AM. |
09-11-2017, 01:34 AM | #739 |
My other problem is brake lights.... Im using a pressure switch inline (like the one below) with the rear brakes. but if I push the pedal it is not turning the lights on. If I have a hydroboost system does it need to be running to get pressure to the switch?
09-11-2017, 02:00 AM | #740 | |
Anyway, I try not to be insulting to anyone so I probably shouldnt have made the joke. Especially not for someone just being who they are.
09-11-2017, 06:14 PM | #741 |
You should still get enough pressure to turn the brake lights on with out the hydro boost running.
09-11-2017, 09:11 PM | #742 |
Brake lights should work whether or not it's running. Have you tried bypassing the brake light switch?
09-12-2017, 02:36 PM | #743 | |
thanks
09-12-2017, 04:23 PM | #744 |
Oh well dont need brake lights anymore cause I just broke off the brake pedal assembly.... can you say MAJOR SETBACK!!!! --- this thing is ready to run! and no brakes!!!
Remember this custom thing I made out of a Wilwood multi-res assembly to go under my floor? Well I just snapped the end of that long 1/2" bolt off that pushed the ram into the booster. I guess Im just gonna have to take the whole thing out and start over with a different idea.... tear up the firewall again and weld in some type of STANDARD brake pedal assembly like regular "white-folk" do..... instead of this redneck backyard mechanic stuff! oh well.... thank God - good thing it happened now instead of out on the street!!!! I need a vacation --- think I'll go to Florida! Okay so this is what I essentially made (from scratch) This is an $80 Porsche clutch lever..... I used just a 1/2"-13 Bolt black steel and then I had to drill and thread 1/4-20 "pins" on either end for the pedal and the lever. So I removed 50% of the bolt material on both ends and thats why it failed right at the 1/4" threaded hole on the lever end. So my question is; - the Porsche lever looks like its just mild steel with a lever welded onto the end - I can't weld the ends on becasue then I can't assemble it under the cab with the trans and everything in the way. It has to be a long rod, slid though the holes and the pedal and then the lever slides onto the end and is sandwiched with locknuts. But the pedal and lever need to be pinned somehow. Drift pins...cannot get a hammer up in there and once in you'll never get them back out. I dont wan it to have any slop either.... Would drill rod material be stronger for threading away 50% of the material? I already tried smaller bolt pins (10.32) and they snapped them right off.
My Build: 57 Chevy Pro-Street Last edited by ptc; 09-12-2017 at 05:27 PM. |
09-12-2017, 10:02 PM | #745 |
I'm glad the failure didn't happen when you were driving on the street. On something that you absolutely want to stay tight and not rotate, I would consider a shaft with a keyway (think crankshaft and harmonic balancer).
It would be a fairly easy job for a competent machinist. |
09-13-2017, 04:46 AM | #746 | |
Would love to come over, have to make a really big trip then. Visit Doug and Cindy, then on to Mark and Jim and then on to the west to you We're just got back from friends in Curacao. We were there when the flooding in Texas began. We flew just in time back, we just missed hurricane Irma.... Bad times for you folks overthere!
09-13-2017, 03:15 PM | #747 | |
09-14-2017, 02:39 AM | #748 |
ptc
You need to do a "redneck lash up" works every time, guaranteed. Just pokin fun at us lost white folks... Don't move it, think bigger is better, you know, works no doubt. Keep on keepin on NC
09-18-2017, 10:52 PM | #749 |
Ok well Saturday was the day we rolled it out and hit the start switch...
its ALIVE!!!! https://www.facebook.com/paul.christ...8155982304738/
09-19-2017, 04:23 AM | #750 |
Yeah baby!!!
People will notice you'll be coming round the corner
