12-15-2020, 01:36 AM | #1 |
350 Cam Intake Valve Closes
Need the degrees after bottom dead center that the intake valve closes for GM
14060651 camshaft. This is the cam used in chevrolet trucks with 350 engine from 1984 to 1996, along with certain current GM 350 crate engines. Thinking some where around 62 degrees. Thanks Last edited by aotte1; 12-15-2020 at 01:43 AM. |
12-16-2020, 10:37 AM | #2 |
Moderator
Re: 350 Cam Intake Valve Closes
Intake: Duration 296 Deg. (195 Deg. @ .050" lift). Gross valve lift is .390". Opening @ 26 BTDC, closing @ 90 ABDC.
Exhaust: Duration 310 Deg. (202 Deg. @ .050"). Gross valve lift is .410". Opening @ 84 BBDC, closing @ 46 ATDC.
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
12-21-2020, 08:40 PM | #3 |
Aussie, Thanks for the information.
Looks like the dynamic compression ratio is kind of low, with the intake valve closing 90 degrees after bottom dead center. Last edited by aotte1; 12-21-2020 at 08:54 PM. |
