01-15-2021, 10:33 AM | #1 |
Big block 1967 c10 panel
Wondering what hedders to use 67 c10 panel,468 bbc motor plate. Wanting hooker supercomps. books dont seam to go back or combo. any help?
01-15-2021, 11:44 AM | #2 |
Re: Big block 1967 c10 panel
SHould be able to use any 68-72 header. 68 was first year for a big block in a pickup, not sure of a suburban/panel chassis, though, but shouldn't matter on the engine compartment.
You do know that the top of the frame is wider on 67 frames? About half of the top has to be cut back to clear big block headers or manifolds...there's info here, not exactly sure how to search for it. I have some pictures someone made if you need... |
01-15-2021, 11:47 AM | #3 |
Already has hedders but want to go with ceramic coated for shows and flow.
01-15-2021, 11:48 AM | #4 |
yes please
01-15-2021, 01:28 PM | #5 |
01-15-2021, 01:33 PM | #6 |
Wow thanks
01-15-2021, 02:59 PM | #7 |
The Hedman Chevelle longtube 68198 fit my BBC equipped '67 nicely and are very show and go shiny! Potential problem areas with these are: clam shell engine stands may need clearance auto tranny linkage and/or tranny mount My install didn't experience any of this ( 700r w/ lokar cable driven linkage, stock BBC stands ) but did need a dimple on one tube at rear lower passenger control arm bushing.
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
01-15-2021, 03:17 PM | #8 |
My good friend helped his son install an LS in a 67 C-10. Son got antsy about how close the headers were to the frame. His Dad is capable of ALL things mechanical. Dad made some nify notches in the frame, EXACTLY where the tubes run. Looks cool, like the factory made them, no pictures, though, right now...
Fat, You do know that you may be able to get your old headers coated? It would save having to modify your exhause system to fit the new headers... |
01-15-2021, 04:57 PM | #9 | |
