12-09-2018, 04:03 PM | #176 |
Re: project "C10 Fever" (68 factory black 396 swb)
Wow, I gotta get over to the build thread side of the house more often... missed all your progress Tim. It looks great. Really REALLY glad you went with the fawn interior, I think it looks perfect. Sharp truck. I may have missed it, but you mentioned earlier you were on the fence for white top or not white top.. Made up your mind yet?
12-10-2018, 12:46 AM | #177 | |
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Project "Little Sister" (70 c10 blue original paint refresh) Project "C10 Fever" (68 factory black 396 swb) Project "Blue Bomb" (70 c30 blue original paint refresh) Project "Vitamin C" (71 c10 orange original paint refresh) |
12-10-2018, 09:51 PM | #178 |
Jackpot...
1/8” clear without adjusting anything. I actually like the look better anyway. Anyone need a nice pair of valve covers??
12-10-2018, 10:19 PM | #180 |
$95 shipped.
12-16-2018, 10:56 PM | #181 |
So while I was under the truck today and noticed my driveshaft yoke hanging out there. It’s over 2-inches out. Yikes! I was driving it like this when I bought it, no weird shakes though. I can’t chance it with the big block. I did some measuring, and it looks like the TH400 I figured I could rebuild later is about 1-3/8” longer (29” vs 27-5/8”, both short shafts). So the engine will come back out. I’ll be better off rebuilding the TH400 now anyway, just another delay. The driveshaft should be just about right but if not that’s an easy cut down or I have a big 3-1/2” driveshaft from a 78 c30 that I can cut down to length.
12-17-2018, 03:44 AM | #182 |
Valve covers look good. Driveshaft should be close once you get the 400 in.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
05-12-2019, 11:14 PM | #183 |
The truck has been sitting patiently. Undisturbed. Collecting dust. Zzzzzzz... Zero progress. Somehow this post helps me feel like I did something. Lol!
05-17-2019, 06:46 PM | #184 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
05-17-2019, 11:43 PM | #185 |
I’ve been saving all the hard to find pieces so one day I can do a factory restoration on this truck like you are doing with yours. I don’t have the time for it in my current phase of life but some day!
08-04-2019, 03:55 PM | #186 |
I couldn’t pass up this big truck tach/air cluster on ebay. Great parts donor to finish off my gauge cluster.
This is how it’s set up currently...
08-04-2019, 07:38 PM | #187 |
Let’s see some more interior pics.
08-04-2019, 11:25 PM | #188 |
The interior still needs some attention as it's mostly un-restored OEM parts. Need to fix the radio hole that someone apparently cut with a spoon, refurb and dye all the fawn vinyl items so they are the same color, and a few other minor things. The door panels and windows are out for new door and glass seals. Here are a few current pictures.
08-05-2019, 08:19 AM | #189 |
Looks good. I like the fawn with the black exterior.
09-10-2019, 08:46 PM | #190 |
Making some progress finally on the engine.
09-10-2019, 11:39 PM | #191 |
Wow she's a beaut!
Good work |
09-11-2019, 01:20 AM | #192 |
Thanks!
09-11-2019, 10:20 AM | #193 |
Lovin' this truck bigtime!
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
09-11-2019, 11:46 AM | #194 |
Nice engine. Wish I had big block money. That suckers gonna fly.
12-08-2019, 09:05 AM | #195 |
Just stumbled in, ...Gonna follow along
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
12-08-2019, 11:21 AM | #196 |
Awesome.
What would you do with the interior if it was yours? Just an idea at this point, but I’m thinking about swapping to a factory correct cloth/vinyl fawn bench seat (like you have been looking into), and dye the other vinyl pieces to match better. Maybe even pull the OE floor mat and go with a gray carpet.
12-08-2019, 11:27 AM | #197 |
Or maybe just the dye and carpet.
Here is Joesjunk’s c30 for a carpet example...
I live in California, but identify as a Texan "If a job's worth doing, it's worth doing well" Project "Little Sister" (70 c10 blue original paint refresh) Project "C10 Fever" (68 factory black 396 swb) Project "Blue Bomb" (70 c30 blue original paint refresh) Project "Vitamin C" (71 c10 orange original paint refresh) Last edited by 68bowtie; 12-08-2019 at 11:34 AM. |
12-08-2019, 12:55 PM | #198 | |
To give a quick answer to your question, I would definitely carpet, and even if not 'factory correct' look into doing the Fawn fabric insert on the Buddy Seats. If that's not viable, then for sure, the Fawn cloth/vinyl bench. Now, on the carpet (and dash pad for that matter) I would love to find them in "Fawn", but I'm not sure it's out there. I did find a dash pad that is listed as "Fawn", but it appears to look a beige color, not even close to the silver that Fawn more closely resembles. On the carpet, I just requested 5 color samples trying to find whatever I can that is closest to Fawn. I will post them in the other thread ( http://67-72chevytrucks.com/vboard/s...d.php?t=797183 ) Just to tie threads together for others ; ) You mentioned "gray" carpet? Do you have a link or photo of the color? (and what color is Joe's carpet?, that looks darn nice ; ) Thanks, Kevin
12-09-2019, 01:08 AM | #199 | |
I haven't looked into carpet colors yet. I'm guessing it's a matter of getting samples of "gray" variations.
12-09-2019, 01:22 AM | #200 |
Here are a few updates on a few details from the past few months...
I bent a stainless hard fuel line to match the contour of the head/valve cover flange. I've only done this a couple times, it's pretty easy to get it close, but extremely difficult to get it perfect. I experimented with -6AN fittings and stainless braided hose for the fuel line and PCV hose. I'm pretty happy with how it came out. Final fuel hose routing...
