01-15-2017, 12:06 PM | #1 |
I need more room in the cab !!!
i'm 6,4 350# what can i do to get more steering wheel to belly room other than steering wheel LOL ? I KNOW LOSE WEIGHT ! lol
94 EXTENDED CAB 64 CHEVELLE |
01-15-2017, 12:11 PM | #2 |
Re: I need more room in the cab !!!
Do a search for shortening the steering column, one post had where you could collapse the shaft and move the column about 4" closer to the dash.
01-15-2017, 12:30 PM | #3 |
thanks.. would moving the gas tank help ?
01-15-2017, 12:37 PM | #4 |
Use a small diameter flat steering wheel on a shortened tilt steering column. Wear dark color T-shirts so the dirty place on your belly doesn't show..
I weigh almost that much but 4" shorter.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
01-15-2017, 01:01 PM | #5 |
This kinda interests me. There have been a few times that I wished I had more room, usually in the winter. Is there a thread out there where someone shows the steps?
01-15-2017, 01:17 PM | #6 |
Previous owner (very good dude) was a big guy . And also a fabricator . He got a few more inches this way .
M.A.G.A. |
01-15-2017, 01:26 PM | #7 |
^^^^^^^^Took a bit for me to notice the mod there.
That looks really cool, but the same result could be had modifying the seat(s) with a lot less effort and no metal work. For the OP, have a look at Finnegan's garage on youtube. This guy had his C10 cab extended to give more room. https://www.youtube.com/watch?v=cy-7EDKbYiE -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
01-15-2017, 01:46 PM | #8 | |
01-15-2017, 01:47 PM | #9 |
where can i get a short tilt column ?
01-15-2017, 01:55 PM | #10 |
I spy lol sorry . Posting from phone and zoomed in one was upside down ... but that's the gist of it .
M.A.G.A. |
01-15-2017, 02:01 PM | #11 |
Have a look at this thread. In there they discuss a method to do what you want:
http://67-72chevytrucks.com/vboard/s...d.php?t=361372 -klb
01-15-2017, 02:07 PM | #12 |
70+ ( Old Skool Club )
This thread is old but shows how to shorten a steering column. As has already been said, a tilt wheel and smaller diameter steering wheel will help as well.
http://67-72chevytrucks.com/vboard/s...d.php?t=191143
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-15-2017, 02:13 PM | #13 | ||
"I ain't nobody, dork."
I'm 6' 5" and go around 265... I fit in my 1972 GMC with a stock wheel and bench seat just fine...
But I grew up in these trucks for 40 years and am used to fitting in them. Gary
01-15-2017, 02:16 PM | #14 |
so im 6' and 340lbs so i can feel your pain in some way. I moved the tank to under the bed, made my own seat brackets for the stock bench, and bought a new tilt steering column which by far made the biggest difference. With the new column, i had to redo the D-Shaft and moved the steering shaft about 3 to 4 inches towards the dash, along with the tilt and small steering wheel, lots of room.
01-15-2017, 02:21 PM | #15 |
i need a tilt..where can i get a shorter 1 than stock that fit like oem ?
01-15-2017, 02:28 PM | #16 |
What I did was install buckets from a Blazer of that period. I then purchased a tilt from a van and did the swap of neutral switch and installed.
01-15-2017, 02:34 PM | #17 |
what model van? thanks 4 the info...
