01-11-2017, 05:31 PM | #251 |
6>8 Plugless........
Re: Daddyjeep Hauler - 85 K30 crew cab short bed
Nice work on the scoop! That metal sure has a mind of it's own once you start placing tacks. It can be a real aggravation. But, you are doing nice work of it.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-13-2017, 01:15 PM | #252 |
I filled in the corners last night. It took a little finesse, but it wasn't too bad. I am pretty happy with how this is coming out.
[IMG][/IMG] [IMG][/IMG]
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
01-13-2017, 01:37 PM | #253 |
That looks mean! You have some fab skills. I vote tunnel ram for the big block haha.
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
01-13-2017, 02:01 PM | #254 |
Thanks, I learn new skills just about every time I walk into the shop. The most important part is that I am not scared to go for it. When I was younger there were a lot of projects that I didn't take on because I didn't know how. Now, I just dive in and see what happens.
Tunnel ram huh???
01-13-2017, 05:19 PM | #255 |
tunnel ram, got to have hilborn injection!
01-13-2017, 07:43 PM | #256 |
That looks awesome! Is the expanded metal staying there?
01-13-2017, 10:17 PM | #257 |
I will have some kind of mesh. It will be finer than the piece in the pic and recessed about an inch into the opening.
01-16-2017, 03:28 PM | #258 |
Awesome job on the hood!!
01-17-2017, 01:32 PM | #259 |
Since I didn't do too well at a pool tournament this weekend I ended up getting a little time in the shop. I started the other side of the hood.
[IMG][/IMG] [IMG][/IMG] I should get the other side panel in and hopefully the corners tonight.
01-17-2017, 03:04 PM | #260 |
Hood looks intense! Very cool.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
01-17-2017, 03:42 PM | #261 |
That is looking very nice! I really like it!
01-18-2017, 01:48 PM | #262 |
Thanks Guys.
Almost done with the basic shape of things then I just need to place a couple thousand tacks. [IMG][/IMG] I need to swing by my steel supplier and see what I can find for expanded metal. I will be using that for the front intake, the rear side cowl vents and probably the grill.
01-18-2017, 06:10 PM | #263 |
That hood is going to be awesome!
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
01-19-2017, 11:40 AM | #264 |
Got kind of a Mad Max vibe to it along with an old WW2 era plane look. That's without paint, regardless, looks awesome!
01-19-2017, 12:34 PM | #265 |
I love this build and the concept behind it. Keep up the good work! When you decide to ditch that front bumper, I would be interested in buying it off you.
01-19-2017, 02:07 PM | #266 | |
I am building a bumper, so we can work something out.
01-21-2017, 09:26 PM | #267 |
I got all of the main structure done. Next is building the frames for the screens in the front inlet and the rear vents. I need to go over to a buddies and use his break for that. Of course I just found out my buddy had a hatchet incident at a scouting event today. Hopefully he is up to me coming over tomorrow.
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] I started cleaning up the back edge. I used some pieces from the donor hood and some generic body repair panels to get the folded edge. [IMG][/IMG]
01-21-2017, 11:18 PM | #268 |
Looks real good. Is the gmt400 in the background another project?
01-21-2017, 11:30 PM | #269 |
That belongs to a buddy of mine. Not really a project, just doing some repairs.
01-23-2017, 03:46 PM | #270 |
Nice work on the hood. It's looking great!
01-23-2017, 08:31 PM | #271 |
I couldn't image grinding all of those tacks...
01-23-2017, 09:05 PM | #272 |
I hear you there. I'm dreading placing those tacks more than grinding them. i did finish welding and grinding one little section tonight. I welded the mounting points for the intake grill.
[IMG][/IMG] I need to get the inside with a dremel or die grinder.
02-15-2017, 01:57 PM | #273 |
I actually started working on my truck again. Nothing too exciting is getting done, but things are getting done. I finished spraying the floor with undercoating and got back to work on the bodywork on the rockers and corners. This area doesn't have to be perfect as I will be coating the bottom six or so inches of the truck with bed liner. Since I had to patch a couple areas on the side cowl area (whatever that is called) I shot some flat white paint I had laying around on it. I really like how the flat white shows the bends and shadows.
[IMG][/IMG]
02-15-2017, 08:06 PM | #274 |
Looking good. Little by little they always tell me.
02-17-2017, 11:27 PM | #275 |
I found some smaller expanded metal and threw together a screen for the intake. I'm not sure if I like the expanded metal or not, but it will work.
[IMG][/IMG]
