01-12-2018, 10:56 PM | #1 |
Temp Gauge
I've read all the threads and I guess I'm just not getting it. Brand new temp gauge in dash. Tested it by grounding green wire, it pegs. New sending unit, no teflon tape, clean threads - 2 so far, AC Delco 8993146 (probably wrong) and BW WT358 . Block grounded. Checked continuity between body of sender and block - good. Weird - also continuity between body of sender and it's blade...? Still, it doesn't move. (Previous owner had an aftermarket gauge in the same spot, it worked fine, I am trying to get it back to stock gauge.) Any suggestions?
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic |
01-12-2018, 11:41 PM | #2 |
Re: Temp Gauge
Maybe both sending units were wrong? AC Delco says OEM for 305 was 213-4792.
01-13-2018, 08:13 AM | #3 |
Re: Temp Gauge
Someone did a big right up on this subject awhile back. And it has to do with the temp sensor. The way I understood it, you almost have to have an OEM sensor. The aftermarket sensors don't jive with the gauge.
My truck still had all the original gauges, but the PO had put in an aftermarket sensor & gauge in. I wanted that all out, didn't like the gauge mounted to the dash. Well long story short, I found the correct sensor and installed it. Hooked the wire back up to it, it was still there. The original gauge still worked. Not sure why they ever changed it to an aftermarket on in the first place. Let me look around and see if I can find the thread.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 01-13-2018 at 08:28 AM. |
01-13-2018, 08:26 AM | #4 |
Re: Temp Gauge
Found it: http://67-72chevytrucks.com/vboard/s...d.php?t=703349
On my last post, there is a link to another thread. Rich Weyand & Hatzie are the ones that are knowledgeable in this dept., and they both have links to other other threads or info. This should help you get squared away. I found this thread before I replaced my sensor, so I din't have any issues.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
01-13-2018, 11:49 AM | #5 |
Re: Temp Gauge
This is it.
I did order the 213-4792 that ACDelco says is OEM. I guess we'll see. I see that most are mounted on the side of the block, but this is where mine was mounted when I got it, but like I said, it was an aftermarket.
01-15-2018, 05:33 PM | #6 |
Re: Temp Gauge
Well now I'm just pissed.
3rd temp sensor, and nothing. According to ACDelco, the OEM sensor. Could it just be from being mounted in the manifold and not the block? It seems to be getting plenty of heat mounted in the manifold, don't see how that would be it, but who knows..? ...help...
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic Last edited by RedBed; 01-15-2018 at 05:42 PM. |
01-15-2018, 06:08 PM | #7 |
Re: Temp Gauge
Sounds like you have a wiring issue. In simple terms, all those sensors are is a heat sensitive resistor. The more the circuit is closed (or opened), the more the gauge will move. If you say the block is well grounded to both the body and the chassis, and the sensor is well grounded to the block, then I would be checking continuity from the sensor wire to where it connects to the gauge cluster. If the wire and the circuit board for the gauges checks out OK, check to see if the gauge cluster has a proper ground. I believe this gauge also has a 12V feed, iirc. If the ground and power to the gauge is also good, then the gauge would likely be faulty.
01-15-2018, 06:47 PM | #8 | |
Re: Temp Gauge
Ok, but if that is the case, wouldn't that keep the gauge from pegging when I ground the wire that goes to the tab? I did test it that way as well. Sure wish I could find a pic of the back of the instrument cluster. I dread pulling that apart again. Just had the truck interior gutted for a few weeks and it's almost back together. :-(
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic Last edited by RedBed; 01-15-2018 at 07:04 PM. |
01-15-2018, 07:19 PM | #9 |
Re: Temp Gauge
I went out and jammed my phone up behind the dash and took some pics. Anybody know which plug/cluster has the temp gauge wire in it?
1 2 3 4 5
01-15-2018, 07:27 PM | #10 |
Re: Temp Gauge
I'm going to look in my manual here in a moment, but is it possible that you're using a coolant temp SENDER instead of a coolant temp SENSOR? One is meant for an idiot light, the other works with a gauge.
Edit: Manual shows #35 Dark Green at the cluster connector as being the signal wire from the sensor. |
01-15-2018, 07:35 PM | #11 |
Re: Temp Gauge
Aftermarket senders are notorious for not matching the OEM resistance curves. Where did you get your new gauge? If it is also an aftermarket, even if it is designed to fit in the OEM cluster, it could also have a non-OEM curve.
The early OEM gauges had a lower resistance curve then the later ones. So a late curved sender paired with a early curved gauge will result in almost no movement, even at full hot. When you do your ground test, are you grounding to the side of the sender, also testing the sender ground? I played this game. Finally found a combo that sorta works. A sender O'Rielly's says is for a 89 Suburban paired with a mid 80's gauge works close. Not perfect. Rather sensitive to outside temps. If it is cold out, the gauge will read about 1/4. If hot out, will read about 2/3. But better then I had for years. |
01-15-2018, 07:37 PM | #12 |
Re: Temp Gauge
I was going to say the dark green wire too. That's the one that's hook up to my sensor
01-15-2018, 08:09 PM | #13 |
Re: Temp Gauge
Bought a 213-4792 AC Delco. Engine Coolant Temperature Sender
AC Delco website where I got the number: http://parts-catalog.acdelco.com/cat...log_search.php Before that, AC Delco 8993146, BW WT358 This is the Gauge - from ClassicParts - https://www.classicparts.com/1973-87...info/24%2D843/ This one, right?
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic Last edited by RedBed; 01-15-2018 at 08:18 PM. |
01-15-2018, 08:26 PM | #14 |
Re: Temp Gauge
Yes that's the dark green wire.
01-15-2018, 08:33 PM | #15 |
Re: Temp Gauge
I know there are 3 posts on the Gauge. Anybody know what other 2 wires correspond to the other 2 posts? And what they are?
01-15-2018, 08:39 PM | #16 |
Re: Temp Gauge
A wiring diagram is what you need. A member, Hatzie. Has all of them on this link. Find your model year, this should help
http://67-72chevytrucks.com/vboard/s...&highlight=PDF
01-15-2018, 08:45 PM | #17 | |
Re: Temp Gauge
This is the description of the BW WT358 sensor you have listed:
The 213-4792 AC Delco sensor is coming up as a gauge sensor, but it also shows that fitment is 1985+ Chevys, which may not be compatible with your gauge, and thus why you might not be getting a reading from it. The AC Delco 8993146 appears to be correct for 1979 and later gauges, and I do realize that you have a 1979, but that was also a crossover year for gauges and you may have late 78 gauges and wiring in your truck. You may need sensor 1513321 if this is the case. |
01-15-2018, 08:46 PM | #18 |
Re: Temp Gauge
You should have +12V on one post, a good ground (<1Ohm) on another post, and the third post should lead out to the sensor (green wire).
01-15-2018, 08:59 PM | #19 |
Re: Temp Gauge
Ok, when the dash cluster was off and the gauge was out, I did test the posts and did show 12v when I went from hot to ground post.
So I guess the next thing to do is maybe jump into the Dk Green wire at the connector, run it through the firewall and connect to the sensor and see if that works. Yes? I do know that from the firewall forward, there is continuity to the end of the wire at the sender.
01-15-2018, 09:06 PM | #20 |
Re: Temp Gauge
I would pull your cluster and test the dark green wire with an ohmmeter, one test lead at the cluster connector, and the other at the sensor connector. If there is an issue with high resistance or no connection, then obviously correct it (firewall connection might be an issue), but if there is little to no resistance in that wire, then either your sensor is faulty, the gauge is faulty, or they are mismatched in resistance values. You mentioned earlier that your gauge pegs when the sensor wire is grounded, which indicates your gauge is working. At that point, I would suspect either a bad sensor, bad ground on the sensor (teflon tape can cause grouding issues. Use PTFE paste instead), or the sensor is functioning but has a different resistance range than the gauge and is not compatible with it.
01-15-2018, 09:35 PM | #21 |
Re: Temp Gauge
Well I jumped a wire into the connector under the dash, and out to the sender, and nada. I rechecked continuity between body of sender and manifold and ground is good.
I guess that means maybe I need to try sensor #4 - the 1513321 (aka G1852) ? AAAARRRRGGGGHHHH I REALLY appreciate the help.
1979 Chevrolet Bonanza/305/4L60/Edelbrock Performer/Holley 600 Classic Last edited by RedBed; 01-15-2018 at 09:44 PM. |
01-15-2018, 09:49 PM | #22 |
Re: Temp Gauge
I would give it a try if you have one available locally or can get your hands on one easily enough. Who knows what has been changed or altered on the truck in nearly 40 years!
Also, if that gauge is a reproduction part, you might try contacting the manufacturer and find out what they specify the resistance range is to operate the gauge. It might make it easier to find a sensor that matches that value, instead of guessing what works. |
01-15-2018, 11:31 PM | #23 |
Re: Temp Gauge
Part of your problem could well be the Classic Parts gauge. There is not a single temp gauge that will work with the OEM sensors across the entire 73-87 range. There are at least two different resistance curves in play. You should call Classic Parts and see if they sell a matching sensor for their gauge.
01-16-2018, 10:36 AM | #24 |
Moderator
Re: Temp Gauge
The OEM and aftermarket equivalent senders will drive the gauge needle no matter the exact thermistor resistance curve. The differences are exactly where the needle ends up at various temps.
You shouldn't install the sender in the intake coolant crossover. Use the LH or, in a pinch, the RH cylinder head TEMP sender location. The sender should work in the intake crossover but it will not work properly. Let's back this train up and look at the behavior.
You can download both 1979-1984 parts catalogs from the manuals thread and find the "correct" GM sensor part # for your truck in the illustration book. Either of these sensors will work as long as the threads are the right size for your head or you have a 3/8-18 x 1/2-14 brass bushing. 1979-1980 CK...8993106...1/2-14 threads Coolant TEMP exc. 250 & Diesel 1979-1980 CK...8993164...3/8-18 threads Coolant TEMP 250 & Diesel 8993146 is for 1983 G, 1979-1984 P, and 1982-1984 CK. THIS WILL DRIVE THE GAUGE... if it's working.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 01-16-2018 at 10:54 AM. |
01-16-2018, 12:44 PM | #25 |
Re: Temp Gauge
Spoke to classicparts.com and asked them if they could tell me what sensor went with the gauge they sent me, and the only info they could give me was for the one they sell, which is their part number.
So I peeled back the sticker on their box, and under it was the distributor of the gauge (counterpart automotive) and called them, and they told me AC Delco G1852 was the right sensor. So I ordered it and have my fingers crossed.
