Old 05-12-2018, 06:38 AM   #1
jojomiamia
Cylinder head change
Hi folks,
I’m wandering about changing my cylinder heads for some perf upgrade.
By now, I have stock heads 113 cc oval ports open chambers (3999241) fitted on a 1972 BBC 402 L47 (3999290) with dome cast pistons 402P30.
And there are so many cylinder heads, as I am not sure to buy the right one.
Some of you guys did already bought heads compatible with this set ?
Thanks,
jojomiamia is offline   Reply With Quote
Old 05-12-2018, 08:15 PM   #2
Mike C
Mike C's Avatar
Re: Cylinder head change
Big block heads can be a challenge if you aren't building your motor from scratch. The problem is that most open chamber performance heads are 121cc which will KILL your compression.
I would be looking at the Edelbrock Oval Port heads which have 110cc chambers. They also mill that head down to 100cc as well for late model TBI 454.
You will need to call Edelbrock and ask them about your piston compatibility if you go that way. I have some closed chamber oval port heads on my 427 (290 casting) and I have looked at the possibility of going to those heads (a) if I need to drop the compression due to detonation or (b) just a more powerful head.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-13-2018, 02:28 AM   #3
jojomiamia
Thanks for your help,
It’s not gonna be easy
