01-16-2017, 10:47 AM | #1 |
Rebuilding Tilt Column question
So, I am doing everything in this build except for the Body/Paint work and the differential gear set up.
I am trying to go through the Tilt Column. I have searched and read all of the posts concerning rebuilding them. My question is besides the special puller used to remove the Housing Cover(J-22708, which is no longer available), what other types of pullers has everyone used with success without damaging the housing? Found out the tool is also J-22598. Have you fabricated your own?If so, can you post any pics? Thanks Last edited by Zeroman; 01-16-2017 at 11:12 AM. |
01-16-2017, 12:38 PM | #2 |
Old member
Re: Rebuilding Tilt Column question
x2 anybody got any info? I got a Van tilt I'd like to rebuild it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-16-2017, 12:42 PM | #3 |
Andy4639, I have found an inexpensive puller which I might be able to modify easily for the job.
I will post back once I receive it, and give it a try. |
01-16-2017, 12:48 PM | #4 | |
Old member
Cool thanks, look forward to any and all help we can share are get.
01-16-2017, 01:07 PM | #5 |
I did everything on my truck except:
Paint Automatic Transmission Internals Dana 60 gear setup Steering gear internals Tilt Column Internals I think I got mine from 70SHORTFLEET on the board. If you're not in the market to buy one from him, I'd bet he'd still know the answers to your questions if you can track him down.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
01-16-2017, 02:33 PM | #6 |
Once you get the turn signal housing off you will want this pin puller also the pull the pivot pins after you remove the spring. I have pulled them without this tool but it is much easier with the correct puller, and its cheap.
https://www.summitracing.com/parts/o...6A8aAvFl8P8HAQ |
01-16-2017, 08:41 PM | #7 |
I was able to get the signal housing off with a plastic hammer. Just light taps and work it off. I used a bolt, a washer and a socket to remove the pins. Take lots of pics and notes. There are lots of parts.
1972 Chevy LWB Roadster 1999 Chevy Silverado 2wd 2015 Chevy High Country 4x4 Crew Cab |
