Old 07-16-2017, 11:18 AM   #1
Deer_hunter_088
Deer_hunter_088's Avatar
Ignition help.
Anyone know how to get the key cylinder out without the key?
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift)
1998 S10ZR2
2005 Silverado 2500hd(tow pig)
Made in the USA, just like my trucks
Deer_hunter_088 is offline   Reply With Quote
Old 07-16-2017, 11:38 AM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: Ignition help.
I have seen folks just use a large screwdriver to get it to turn, then use a small pin or allen key to get it out.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 07-16-2017, 12:56 PM   #3
randy500
Re: Ignition help.
Drill out the cylinder, small steps at a time so you don't drill into the ignition switch, when the lock cylinder gets thin, crack it with a screwdriver to make the diameter smaller overall then pull out with needle nose, done it many times.
randy500 is offline   Reply With Quote
Old 07-16-2017, 02:03 PM   #4
panhead59
Re: Ignition help.
Yeah, unfortunately it must turn, by one method or the other to remove. I'd pay a locksmith to try and make a key or whatever they do, before I would start drilling. But that's just me. It is a real PITA. Also Drill out the little pin on the side, if it has one, if you HAVE to resort to drilling. The good news is that a new key cylinder is only about 20 bucks. Just don't hurt the area outside the cylinder while drilling.
panhead59 is offline   Reply With Quote
Old 07-16-2017, 02:15 PM   #5
randy500
Re: Ignition help.
It's aluminum pot metal, the easiest thing you will ever drill, takes minutes...
Old 07-16-2017, 02:34 PM   #6
lowbucktrucks
Re: Ignition help.
I just had this problem , lost keys to 70 swb. I tried to drill out center of lock and turn with screwdriver, no luck. I then unplugged ignition switch from lock cylinder and unscrewed bezel as far as possible. Then took approx 1/8 drill bit and started drilling holes in lock cylinder around edge as close to bezel as possible. after drilling 2/3 around cyl bezel came off. bezel was reuseable, made one or two small spots on threads, but not bad. (much better than punching out dash as was recommended to me) Utube vidio showed somebody trying to get it out with slide hammer and finally giving up. if you do mess up bezel it is available from both wes (classic heartbeat) & gmcpaul among others and it was even in my lowbuck budget. I did not replace bezel but did replace lock cyl and switch(bought kit with new matching door locks and glovebox locks)
Hope this helps
lowbucktrucks is offline   Reply With Quote
Old 07-16-2017, 02:35 PM   #7
midniteblues
midniteblues's Avatar
Re: Ignition help.
If your passenger door and lock are original too the truck the door lock on the pass. Side will have the key code too get a key made.
That is if you didnt already booger up the ign. lock.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 07-16-2017, 02:36 PM   #8
lowbucktrucks
Re: Ignition help.
did not try drilling out pin, might want to try this first
Old 07-16-2017, 03:22 PM   #9
randy500
Re: Ignition help.
Do not drill out the pin, it's part of the ignition switch.
Drill right through the key slot, start with about 3/8 bit, then step up till one side gets thin, then collapse it inside the hole to free the locking key way.
Old 07-16-2017, 10:57 PM   #10
Deer_hunter_088
Re: Ignition help.
Doors are off a 71 ignition from a lord knows what year. Trucks a 69. Ignition is sittin on my desk. I want the truck where i can turn it over with a screwdriver for now.
1998 S10ZR2
