07-17-2017, 09:16 PM | #1 |
rear end
I have a 72 c-10 and would like to know what the rear end ratio is, there is no tag. I know there are other ways of figuring it out but don't know what they are. Any instructions or methods will be greatly appreciated.
bill
The pessimist is one who feels bad when he feels good for, fear he'll feel worse when he feels better |
07-17-2017, 09:33 PM | #2 |
Re: rear end
Search the site first,
http://67-72chevytrucks.com/vboard/s...d.php?t=578793 http://67-72chevytrucks.com/vboard/s...d.php?t=455117
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
07-17-2017, 09:34 PM | #3 |
Re: rear end
Pop off the cover count the teeth on the ring gear the look in and count the teeth on the pinion divide ring by pinion and that's your gear ratio. That's the definitive way to be absolutely sure.
07-17-2017, 09:35 PM | #4 |
Re: rear end
Courtesy of LocDoc...
Rear Axle Ratios Ratio 2.56:1 - Tooth Combination 41,16 Ratio 2.73:1 - Tooth Combination 41,15 Ratio 3.07:1 - Tooth Combination 43,14 Ratio 3.08:1 - Tooth Combination 40,13 Ratio 3.08:1 - Tooth Combination 37,12 Ratio 3.31:1 - Tooth Combination 43,13 Ratio 3.36:1 - Tooth Combination 37,11 Ratio 3.42:1 - Tooth Combination 41,12 Ratio 3.55:1 - Tooth Combination 39,11 Ratio 3.73:1 - Tooth Combination 41,11 Ratio 4.10:1 - Tooth Combination 41,10 Ratio 4.11:1 - Tooth Combination 37,9 The tooth combination numbers will be found stamped into the ring gear when you take the back cover off. They may not all be for the trucks.
07-17-2017, 09:41 PM | #5 |
Re: rear end
If nothing else, you can pull the cover off and look at the ring gear. The number of ringer gear and pinion teeth is usually stamped onto the outside of the ring gear. Example, "41-10", which is a 4.10. Or if it isn't marked like that, just count the number of ring gear teeth and divide by pinion teeth.
