Old 05-22-2002, 04:54 PM   #1
ViperRed67
Post Vent window rubber? HELP!!!!
Ok, I got all the new rubber and channel for the vent windows on my 67. I even bought new hardware from LMC to install them as there appears to be some form of special rivets holding things in place. Well, In the pack of rivets there is a little tool that looks like a center punch of sorts. How am I suposed to attach these things? A pop rivet tool will not work on them. Any help is welcome. Thanks!
ViperRed67 is offline   Reply With Quote
Old 05-22-2002, 05:52 PM   #2
timbogmo
Lightbulb
What a coincidence, I am having, or rather, have just had the same problem except I bought my seals from Chevy Duty. Anyway, when I find an excuse to buy a new tool I do it. I purchased a $13 pop rivet tool and purchased a couple packages a varying length 1/8" diameter pop rivets. They are fun to use a work well. By the way, how do you put the window and vent window back in. Its been a pain, neither want to go back in easy. Thanks, -Tim
timbogmo is offline   Reply With Quote
Old 05-22-2002, 05:53 PM   #3
Speedy1968
Post
I had the same problem with rebuilding my vent windows. I ended up putting the flat side of the rivets on a hard surface, then placing the "punch" looking thing on the other side of the rivet, and using a hammer to flatten that end. It worked pretty good besides a few that i couldnt get the punch very straight on.
68 long fleetside
67 camaro
83 monte carlo
88 SS monte carlo
Speedy1968 is offline   Reply With Quote
Old 05-22-2002, 06:03 PM   #4
ViperRed67
Post
I have been looking at it, and thinking maybe a large C clamp used to cruch down the rivet heads may work. I dont know. I am thinking about farming this job out so I have someone to scream at if they still whistle! :0
Old 05-22-2002, 06:33 PM   #5
photoglg
photoglg's Avatar
Talking
You use the tool (punch) to spread the rivet it rolls the hollow end over, when you drill out the old rivet dont make the hole any bigger. You should have got special rivets for the window henge. Make sure that you paint the frame be for you assemble.
1969 GMC S/B S/S 3" drop
photoglg is offline   Reply With Quote
Old 05-22-2002, 06:38 PM   #6
Benrs86
Benrs86's Avatar
Post
hold a bigger hammer on the backside of the rivet. put the tool(cant think of the correct name right now) on the other side of the rivet and hit it with a bigger hammer. its not that hard. good luck, Ben
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Brandon, SD
69 GMC 1/2 ton 2wd
3 on the tree
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 05-22-2002, 06:40 PM   #7
Paul Clark
Post
I haven't "been there - done that" yet, but I'm about to.
Would it work to put the assembly in a vise with the tool behind the rivet and then tighten down the vise?
Paul Clark is offline   Reply With Quote
Old 05-22-2002, 08:49 PM   #8
Tim Christian
Tim Christian's Avatar
Cool
I cheated! I bought new vent window assemblys from Kingparts.
67 GMC Stepside(UNDER CONSTRUCTION)
67 GMC Custom
67 Chevy C-30
Tim Christian is offline   Reply With Quote
Old 05-22-2002, 09:17 PM   #9
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Post
how much did those window assemblies cost?
And for those of you that have painted the bars and the frame of the vent window, what paint do you recomend and how would you go about doing so.
-Roger
IN A TUX WITH A 68 BOWTIE.
*SELLING FOR PARTS*
"P.O.S" Stepside 68, Primed from Fl., rusted out a bit, but
*SELLING FOR PARTS*
Interested? E-mail me!!
"Rusty" Stepside 68 Brown/Black (not by choice, soon to be charcoal grey)
This is my baby, just put in wood bed.
Overhauled 307.
Just needs the brakes to be redone then its ready to run.
Oh yeah, My girlfreind's got a 63 named "Blue Boy"
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 05-23-2002, 08:07 PM   #10
photoglg
photoglg's Avatar
Post
The way mine were done we used a ratchet handle in a vise and the tool and a hammer.
I did't like the way mine came out so I bought new ones from Rick's for $129.00 each. The quality of the ones I got suck.
