Old 12-16-2018, 10:14 PM   #1
clemsonteg
Core support mounts
The core support frame mounts on my 66 has a rubber mount between the frame and the actual perch that the core support rests on. Are these reproduced? I can find the small rubber washers, metal washers, and replacement carriage bolts, but not this motor mount like perch.
clemsonteg is offline   Reply With Quote
Old 12-16-2018, 10:37 PM   #2
clemsonteg
Re: Core support mounts
I don’t have a picture of mine at the moment, but this is what it looks like. You can see the rubber bushing between the frame and that perch. The pieces appear to be bonded together and riveted to the frame.
Old 12-16-2018, 11:04 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Yes they are reproduced.
https://www.classicparts.com/1960-68...info/78%2D625/
And a great post about how they are installed - http://67-72chevytrucks.com/vboard/s...82&postcount=6
Old 12-16-2018, 11:37 PM   #4
clemsonteg
Thanks, but I’m not talking about the rubber between the core support and the perch, if you look in the photo, there is rubber between the frame and the perch.
Old 12-17-2018, 12:14 AM   #5
Captainfab
60-66 Nut
I don't know of anyone that reproduces the Suburban/Panel radiator support mounts. If yours are coming apart, you may be able to have them rebuilt much the same as is done with the C20 and up rear cab mounts. I believe it is Steele Rubber that offers that service.
Old 12-17-2018, 09:42 AM   #6
The Rocknrod
Moderator
I guess my eyes cant see that. Is it laminated rubber? - https://www.mcmaster.com/cloth-inserted-rubber
Old 12-17-2018, 11:23 AM   #7
clemsonteg
Thanks Cap. Wasn't sure if it was a burb specific part or unique to 60-66. They don't appear to be in bad shape now, but I was going to spend the time replacing them if they are available since I have everything torn down.
