Old 07-03-2018, 11:49 AM   #1
WhiteCST
WhiteCST's Avatar
68 C10 frame damage
Possibly a noob question, but this frame has obviously been hit and I’m wondering if bends/damage like this can be corrected? Again sorry if this is an easy yes or no, I just have zero experience with framework.
1953 Kaiser Manhattan “Sled”
1968 C10 CST LWB
1991 Trans Am GTA “White Nasty”
2006 Dodge Charger RT
Built TH400 for Sale
WhiteCST is offline   Reply With Quote
Old 07-03-2018, 12:06 PM   #2
Jeff's bowtie's
Re: 68 C10 frame damage
If your talking about the rear cross member being bent I don't think it was hit . Looks like someone hooked a chain to it and pulled on it. I would think you could replace that crossmember with a straight one and it would be fine
Jeff's bowtie's is online now   Reply With Quote
Old 07-03-2018, 12:50 PM   #3
WhiteCST
WhiteCST's Avatar
What about the piece ahead of it? Is that bend normal?
1968 C10 CST LWB
Old 07-03-2018, 12:53 PM   #4
Lanman1972
Lanman1972's Avatar
That crossbar is angled slightly from the factory.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB, 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 07-03-2018, 01:19 PM   #5
Jeff's bowtie's
X'2 on angled from the factory just replace the bent one and it should be okay
Old 07-03-2018, 03:18 PM   #6
ncpetersc
ncpetersc's Avatar
I'm picturing someone hooking to a tree stump with some slack in the chain and flooring it.
ncpetersc is offline   Reply With Quote
Old 07-04-2018, 05:50 AM   #7
hamjet
hamjet's Avatar
But it works! lol....
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB, no power anything...
hamjet is offline   Reply With Quote
Old 07-04-2018, 07:45 AM   #8
CG
BlahBlahBlah
Super common to see those bent like that. I had a board member come out and pick up a bare frame from me. Used that cross brace to pull it onto the car trailer. It bent. He was like ... Gah I knew better than that to use that to pull on.
Old 07-04-2018, 08:58 AM   #9
jjzepplin
jjzepplin's Avatar
I have one of those if you need it. I see you also have overload springs there. I am interested in those if you are taking them off for any reason.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 3.73 posi-4-speed Saginaw-307-no budget build.
58 Belair http://67-72chevytrucks.com/vboard/s...d.php?t=756563
jjzepplin is offline   Reply With Quote
Old 07-10-2018, 07:07 AM   #10
jjzepplin
jjzepplin's Avatar
I found it.
Old 07-20-2018, 08:47 AM   #11
jjzepplin
jjzepplin's Avatar
Just surface rust. Still want it?
Copyright ©2000 - 2018, vBulletin Solutions Inc.
