Old 06-18-2017, 04:11 AM   #176
520-k5
520-k5's Avatar
Re: project orange crush 76 crewcab build
So close to finished
520-k5 is offline   Reply With Quote
Old 06-18-2017, 04:16 AM   #177
520-k5
520-k5's Avatar
Door back on
Old 08-03-2017, 12:15 AM   #178
520-k5
520-k5's Avatar
Haven't done much too the truck lately it's monsoon season so every time I wanna work on it it wants to rain. I got the driverside pretty much all finished up. Took the cowl panels too work and stripped them to bare metal and epoxy primed them. Cut out a filler panel for the driver side kick panel vent hole and I filled in the hole in the trans tunnel cover. Hopefully I'll get started on the pass side floor soon.
Old 08-20-2017, 03:44 AM   #179
520-k5
520-k5's Avatar
Got started on the pass floor this week.
Old 08-20-2017, 03:47 AM   #180
520-k5
520-k5's Avatar
The inner rocker was in better shape than the driverside so I didn't need to replace the whole thing just a section of it.
Old 08-20-2017, 03:51 AM   #181
520-k5
520-k5's Avatar
This pass side floor pan didn't fit well at all. Took allot of massaging to get it flat against the supports and close enough to weld.
Old 08-20-2017, 03:56 AM   #182
520-k5
520-k5's Avatar
Finally the end is in sight! I'll get the outer rocker trimmed and fit tomorrow and welded on then I can weld the cowl panels back.on and start bodyworking the firewall finally can't wait to get all this metal work done so I can get some color on this and install my ls swap
Old 08-20-2017, 04:05 AM   #183
520-k5
520-k5's Avatar
Here's a parts blazer that Ive had and finally got it cut up and have been playing around with some yard art idea's. Thinking this would look cool mounted against my wall or maybe even incorporate it into my gate not sure what the end goal is just yet but when the weather cools down I'll get back too it.
Old 08-27-2017, 03:38 PM   #184
520-k5
520-k5's Avatar
Got the rocker and cowl welded up. Ground down all the welds and got some primer on everything. Rehung the door with the rebuilt hinges and got it all mocked up for now. Still need to finish the driverside cowl then I'll get that side in primer and start bodyworking the firewall and rockers
Old 08-27-2017, 03:44 PM   #185
520-k5
520-k5's Avatar
Looks good in primer
Old 08-28-2017, 02:37 AM   #186
520-k5
520-k5's Avatar
Mocked up the fender for the first time in over a year kinda nice to see it looking like a whole truck again. Also picked up a door for the yard art project.
Old 08-28-2017, 01:04 PM   #187
oldgymnast
Nice job. Been watching what you do since I'm trying my hand at replacing my rockers and floors in my c30 shortly. Thanks for all the pictures.
oldgymnast is offline   Reply With Quote
Old 09-23-2017, 12:59 AM   #188
520-k5
520-k5's Avatar
No problem there's also some good how to videos on YouTube that a guy did specifically for 73-87 trucks
Old 09-23-2017, 01:18 AM   #189
520-k5
520-k5's Avatar
Got the driverside in epoxy and 2k primer then I hung the door and fender again to check fitment
Old 09-23-2017, 01:29 AM   #190
520-k5
520-k5's Avatar
Just about totally gutted time to start the bodywork on the firewall, rockers and get everything in primer and ready for paint.
Old 09-23-2017, 01:37 AM   #191
520-k5
520-k5's Avatar
So heres my newest project to flip. I was browsing facebook sales and this was posted for 1k so I messaged the seller and was on my way. I got there first with cash and it was ment to be so here's my new 75 Chevy c20
Old 09-23-2017, 01:43 AM   #192
520-k5
520-k5's Avatar
Gave it a wash and put two of my torque thrusts on to move it gotta say this truck sure has alot of potential
Old 09-23-2017, 01:54 AM   #193
520-k5
520-k5's Avatar
Theres no drivetrain but ive got a 350,th400 that im going to install in it. The interior needs work but its all there. I'll post updates on this one as I work on it
Old 09-25-2017, 12:14 PM   #194
daddyjeep
daddyjeep's Avatar
That is a good find for a flip. A little work and you should make a nice profit.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 09-25-2017, 03:38 PM   #195
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice work on your crew cab, and nice score on the 75! That will make a nice truck with a little bit of work. Like daddyjeep said, it should yield a very nice profit!
Ryan
1969 Chevy milk truck
Old 10-06-2017, 07:46 PM   #196
520-k5
520-k5's Avatar
Sure is couldn't pass it up for the price.
Old 10-06-2017, 07:47 PM   #197
520-k5
520-k5's Avatar
Thanks it sure is coming along now
Old 10-06-2017, 07:50 PM   #198
520-k5
520-k5's Avatar
Got the passenger side all sanded and primed
Old 10-06-2017, 07:56 PM   #199
520-k5
520-k5's Avatar
Bodyworked my driverside fender. It's ready for primer and block sanding rounds now. My pass side fender needs some rust repair and is in rough shape overall still unsure if I should put the time into this one of find a better replacement
Old 10-06-2017, 08:41 PM   #200
Dieselwrencher
Looking nice! I'm not sure on the fender. If you can find a nicer one close to you then getting a different one would work. But my luck you can't find any near me so I'd spend the time and fix it. Haha
Ryan
