Old 01-12-2018, 06:57 PM   #1
fredhlynch2
Need Help - Steering Column Disassembly
64 C10 steering column I'm taking apart to replace trashed bearings and clean. See the attached photo. Can anyone tell me how to separate the outer from the inner column. Seems to be under spring tension. Apparently I'm missing something. Someone had a great thread or video on here how to do it but can't find it.
fredhlynch2 is offline   Reply With Quote
Old 01-13-2018, 01:16 AM   #2
vetnat
Re: Need Help - Steering Column Disassembly
I did this for my own column last spring. Here are the directions from the 1960 shop manual. Need to step on the upper lever to compress the spring, then tap from the top of the column with a wooden block. Mine took some doing, but I didn't need a BFH or anything. It's step #5 and fig 26, sorry for rotated pic. "Mast jacket" is the outer tube.
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 01-13-2018, 04:36 AM   #3
fredhlynch2
VETNAT,
Thanks for the reply. Seems simple enough.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
