Old 09-07-2008, 11:24 PM   #1
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Factory Tow Hooks mounting holes 1969-1972 style
Hey guys, my dad and I have decided to tear down my 1971 swb 4x4 once again and we are needing the dimensions for the factory tow hook mounting holes on the frame horns. The previous owner oxy torched holes out for mounting the 1973 + style tow hooks on it. Since we are tearing it all the way down, we are going to do it right and re weld up the holes and drill them correctly. If anyone can do some measurements for me and possibly take a few pictures labeled, I would greatly appreciate it. Thanks Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 09-08-2008, 09:57 AM   #2
71blksuper4x4
SWB 4x4 Collector
Re: Factory Tow Hooks mounting holes 1969-1972 style
ttt
TREVOR
Old 09-08-2008, 10:09 PM   #3
71blksuper4x4
SWB 4x4 Collector
Didn't know if this would help anyone out to label the measurements for me. I figured if anyone could measure from the center of the front stock hole in the frame for me for starting points, it would be easy. Thanks guys, I just hate to weld up the holes, paint the frame, and then redrill the holes. Trevor
TREVOR
Old 09-09-2008, 12:17 AM   #4
Keep on Trucking
Keep on Trucking's Avatar
If you have the hooks you can use them as a template?
1970 4X4, Big block 454, 4 speed, vintage air, Mahagony wood bed, Tilt, tach.
Can have new owner for the right price.
"Life is tough, its tougher if you are stupid" (John Wayne)
My buddys truck for sale here.
http://67-72chevytrucks.com/vboard/c...p?product=2676
Keep on Trucking is offline   Reply With Quote
Old 09-09-2008, 09:06 AM   #5
71blksuper4x4
SWB 4x4 Collector
Yeah I do have the hooks and I know I can use them as a template, but if I don't get the location right, they will hit the front bumper. We already have the body off the frame, so that is a no go on getting measurements. I just thought maybe someone could run outside for 5 min. and take a couple of measurements for me. Trevor
TREVOR
Old 09-09-2008, 09:53 AM   #6
Keep on Trucking
I will see if I can measure mine tonight.
Old 09-09-2008, 03:59 PM   #7
72swbcamo
Active Member
Did you get the measurments you need yet? If not I can make a cardboard template of the bolt holes and send it in the mail. PM me if you are interested.
72swbcamo is offline   Reply With Quote
Old 09-09-2008, 08:41 PM   #8
71blksuper4x4
SWB 4x4 Collector
KeepOnTrucking- I greatly appreciate it if you take the time to get some measurements, if you don't I appreciate you taking the time to respond to my thread.
72swbcamo- I am going to see if Keep On Trucking gets measurements today. If he can't and you don't mind doing that I would sure appreciate it. I will send you a couple of dollars for your time and shipping. I will pm you my address
TREVOR
Old 09-09-2008, 10:10 PM   #9
Keep on Trucking
Hello, just got back. I went to look at my frame, but do not see three holes where I thought you were tring to fix. Below is a pic of mine. Picture is of driver side where bumper mounts to the frame. You are tring to fix the front end of the frame right? because now that im typing this I seem to remember three holes in the rear.
Old 09-09-2008, 11:50 PM   #10
71blksuper4x4
SWB 4x4 Collector
Thanks Keep on Trucking, you are correct that I am looking to weld up and re-drill out the front factory holes for the correct tow hooks. It appears that your truck did not come from the factory with tow hooks. If it did, there would be two slanted holes behind that hold that is in the middle of your frame rail. It is the placement of these two holes that I wanted to know the placement of. I appreciate you taking the time to help me out.
TREVOR
Old 09-09-2008, 11:53 PM   #11
Keep on Trucking
OK I learned something new. Im supprized they would make a different frame or do they just drill new holes at the factory?
Old 09-10-2008, 01:53 AM   #12
Mint68
Mint68's Avatar
I think they would just drill the additional holes.
Mint68 is offline   Reply With Quote
Old 09-10-2008, 10:23 AM   #13
Yukon Jack
Yukon Jack's Avatar
You might go ahead and post this same question in the 4x4 subforum and maybe even the first gen K5 forum and the Suburban forum - someone surely can help you out. I know there are a number of people on the board with installed tow hooks.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-22-2008, 10:42 PM   #14
70 CST 4X4
Have A Nice Day!
70 CST 4X4's Avatar
Ttt
1970 CST K10 350/350/205
Short Bed - Fleetside
Tach-Tilt-A/C-Tow Hooks
Front & Rear Disc Brakes
Front & Rear Posi 3.73 Gears
30 Gallon Stainless Fuel Tank
SOLD 01/18 !!!!!
2007 2500 HD Classic Crew Cab LT2 4X4 Duramax LBZ
70 CST 4X4 is offline   Reply With Quote
Old 09-22-2008, 11:54 PM   #15
trx450duner
trx450duner's Avatar
Just checked mine and I dont have the tow hook holes either sorry. But I too would be interested in this info.
trx450duner is offline   Reply With Quote
Old 09-22-2008, 11:58 PM   #16
71blksuper4x4
SWB 4x4 Collector
Thanks guys for bringing this back to the top. I am still needing some sort of template to get this corrected before getting my frame powder coated or painted. Trevor
TREVOR
Old 09-23-2008, 06:11 AM   #17
I thought they all had holes,too.Then,I saw a 2wd w/o them and figured 2wds only had them if they got the hook option.All the 4wds I`ve had came with holes.Most didn`t have the option.
Would you rather drill the holes or splice new horns with them?I imaging the welds could be tough to drill.If no one gets the numbers I`ll check it out this evening.
Old 09-23-2008, 09:35 AM   #18
haysonj
haysonj's Avatar
My 4x4 frame doesn't have the holes maybe they only drilled if you ordered hooks
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 09-23-2008, 06:26 PM   #19
71blksuper4x4
SWB 4x4 Collector
That would be great Tim. Hey, did you happen to ever shoot a pic of those blue belts? Thanks Trevor
TREVOR
Old 09-23-2008, 08:48 PM   #20
Trevor,I forgot until it was too dark.I can do both in the morning.
About no holes in 4wd...I don`t have a clue because I`ve had alot of 4wds and have always had holes,at least the ones I checked.I`m talking about trucks that never came with hooks.I`ve seen 2wds w/holes that never had hooks.What would be really rare and odd would be a truck w/hooks w/o holes.I`ll laugh because I`m sure no one else will and I don`t want to feel bad.
Old 09-23-2008, 09:27 PM   #21
Classic Bowties
Always on the hunt...
Hey Trevor, I researched this a couple years ago and it is my understanding that the hook mounting bolt holes became a standard deal in 72 and were found on all K series frames. I would think that you should be able to locate a 72 4wd in your area to get this template traced out (I always liked doing this type stuff myself, especially if/when drilling), it could be a truck, blazer or burb. If you do not know anyone local with a 72 K, then maybe try your area wrecking yards in search of a 72 K frame. Good luck on your hunt,
Classic Bowties is offline   Reply With Quote
Old 09-23-2008, 09:45 PM   #22
Rod
no measurements but here a pic
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 09-23-2008, 11:30 PM   #23
'71 Lil'Beag
Here are mine.I drilled them. The holes are 4.75 from the front or 2.5 from the other hole.The bottom hole is .125 off the top hole. It may not be factory but they fit good.
71 4x4 SWB 350
72 C-10 LWB SOON TO SWB
Salt Lake City, UTAH
'71 Lil'Beag is offline   Reply With Quote
Old 09-24-2008, 06:44 AM   #24
I should just make a template and mail it,if you want.I`ll get the measurements in the meantime.
Old 09-24-2008, 09:20 AM   #25
71blksuper4x4
SWB 4x4 Collector
Hey Tim, yeah if you would want to make a template out of cardboard for me that maybe has the round frame rail edge from the inside and just follows the contours of the frame rail with the holes poked in. I will gladly pay you for your time doing that and shipping it. Thanks a bunch Trevor
TREVOR
