Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 02-11-2018, 01:55 PM   #1
Advanced Design
Advanced Design's Avatar
Bought a new high quality locally built car trailer
In December I found a vehicle six hours away I thought I wanted. Hauling it home would be no problem as I have a trusty old car trailer built in 1990 that has always worked fine.
Then I started evaluating the condition of the trailer and remembered it needed new tires, bearing packed, as well as electric brakes repaired and upgraded. Then I started comparing dimensions of this one to new ones and determined my 1990 model was only 76" between the fenders, making it difficult to impossible to open a door on a loaded vehicle.
This all helped me decide to just go ahead and get a new trailer as wife and I had been discussing for several years. Doing some comparison on how trailers are built showed a lot of variation in structure, quality and materials. Since I wanted a really well built unit, I custom ordered one from Imperial Trailers in Olney, IL.
Their design incorporates a triangular shaped side, fabricated from box tubing, creating a very stiff deck. This one has the 23' deck, 6 D rings, rub rail with stake pockets, 6k torsion flex axles, Dexter EZ lube hubs with up graded electric brakes at each hub, 16 inch 10 ply trailer tires, 2 coats of primer, and 2 coats of paint top and bottom. We stepped up on the jack capacity and also included are the safety chains with emergency stop break away. The deck steel thickness was also doubled.
Advanced Design is offline   Reply With Quote
Old 02-11-2018, 01:59 PM   #2
Advanced Design
Re: Bought a new high quality locally built car trailer
The beaver tail ramp includes a stepped down area, making it a little easier for this too fat getting older guy to wriggle under and place tie downs in place. I also like the signal lights, one is included in the fenders.
Old 02-11-2018, 02:02 PM   #3
Advanced Design
The loading ramps are stored here in the split, and are extended after pulling the retention pin out from the side. They provide a pretty low load angle.
Old 02-11-2018, 02:05 PM   #4
Advanced Design
I looked at another manufacturers product which included stabilization jacks on the back corners of the trailer. They were to be used when loading. This Imperial doesn't need those.
Old 02-11-2018, 02:07 PM   #5
Advanced Design
Added the 8,500 lb winch as well. It mounts on a removable post and came with a wireless as well as a wired remote.
Old 02-11-2018, 02:11 PM   #6
Advanced Design
The lockable tool box contains the winch battery and enough room for other storage too. I will put some post protectors on the unprotected positive post. The battery is wired to charge from the truck. I'll throw a trickle charger on it as mostly it will be sitting in the shop.
Old 02-11-2018, 02:17 PM   #7
Advanced Design
This company is part of Floyds welding who has been in business 75 years. They do a lot of oil field work, including fabricating and installing all the equipment on big trucks for pulling and servicing oil wells.
So I figured they would have good welds and a product that will last.
Check them out here....https://imperialtrailer.com
Old 02-11-2018, 02:58 PM   #8
mongocanfly
that's a really nice trailer you got there Doug....looks really well built....that wireless remote winch is the ticket...
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
mongocanfly is online now   Reply With Quote
Old 02-11-2018, 06:49 PM   #9
Scott2
Sweet! I was just hoping to find one like your old one!
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 02-11-2018, 06:52 PM   #10
Clyde65
Clyde65's Avatar
Wow! A lot of trailer right there! Nice!
Clyde65
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-11-2018, 08:49 PM   #11
truckster
truckster's Avatar
That should haul whatever you need it to.
If I didn't build it or fix it, it's probably not mine.
truckster is offline   Reply With Quote
Old 02-12-2018, 11:57 AM   #12
wahl4m
doug -thats a really NICE TRAILER !!!! looks like it is set -up realy nice & should tow really good -especially like the bigger axle & the 16" wheels & tires ! YOU DID GOOD !! say hi to randy f for me !!!!! mike
wahl4m is offline   Reply With Quote
Old 02-12-2018, 12:37 PM   #13
Advanced Design
Thanks guys. It should handle about any vehicle hauling needs I will ever have.
Mike, I will say hey to Randy. Come on back to MM this year!
Old 02-12-2018, 05:54 PM   #14
gearheadperkins
gearheadperkins's Avatar
very nice trailer.. Congrats..
1972 Chevy C10 400sbc 4sp
Matthew 4:19
And he saith unto them, Follow me, and I will make you fishers of men.
gearheadperkins is offline   Reply With Quote
Old 02-14-2018, 12:58 PM   #15
Advanced Design
Thanks gearheadperkins! Now to go buy a truck somewhere....
Old 02-14-2018, 01:20 PM   #16
wahl4m
know of any deals on a dually ?? were out of money after buying a 5th wheel trailer !id like to find something as nice & dependable as "jerry gullys " unit
Old 02-14-2018, 01:54 PM   #17
Advanced Design
I don't know of one specifically Mike. Jerry has a nice one and has been putting it to work towing his trailer for several years now. Ours is decent though this one is a keeper for me. We really like it.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
