Old 09-13-2012, 02:36 PM   #1
91Subbed
Negative camber
I have 91 suburban 2wd 350. I installed 2 1/2" drop spindles and 2" lowering shackles. Now I have my front wheels going in on top. Any help with this???
91Subbed is offline   Reply With Quote
Old 09-13-2012, 03:21 PM   #2
UKNOWME
UKNOWME's Avatar
Re: Negative camber
HMMM, that's weird because I thought the spindle was just moved up on the knuckle therefore not actually changing the alignment angles and still having the same spring and shock travel.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 09-13-2012, 03:43 PM   #3
91Subbed
Re: Negative camber
That's what I thought.
Old 09-14-2012, 12:10 PM   #4
BaggedRanger
BaggedRanger's Avatar
Re: Negative camber
did you get it aligned after changing the front end? Anytime you change the front suspension you should have it aligned. Once you get it aligned then you won't have the negative camber.
As an example when I swapped the i-beams on my ranger for dropped ones it did the same thing.. General rule of thumb, when you change the suspension always get it aligned.
BaggedRanger is offline   Reply With Quote
Old 09-14-2012, 01:23 PM   #5
91Subbed
Re: Negative camber
I'm gonna try that tomorrow, thanks!
