05-21-2019, 10:33 AM | #1 |
Engine mount questions
I'm replacing the engine in my '67 after I pressure wash and clean up the frame and suspension.
So my question is, is it easier to remove the frame mounts as pictured and bolt them to the new engine mounts first; or leave them in place and just try to line up each bolt to the engine mount to the stands when going back in? |
05-21-2019, 10:37 AM | #2 |
Re: Engine mount questions
Leave them as-is
I'd straighten out the trans first though |
05-21-2019, 10:40 AM | #3 |
05-21-2019, 12:12 PM | #4 |
I would loosen the bolts on the frame mounts so you have a bit of play to make it easier to get the center motor mount bolts to start as you lower the engine.
Here is a link to a couple of motor mount tips. http://67-72chevytrucks.com/vboard/s...d.php?t=773824
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-21-2019, 12:29 PM | #5 |
I would also loosen the frame mount bolts, so that they can wiggle a bit. It's a pain to loosen and re-tighten them, but totally worth it.
'59 Apache - 383" SBC/TH-350 '68 GMC - BBC/TH400 |
05-21-2019, 02:23 PM | #6 |
Would this be the time to convert the mounts to the single center bolt style somehow? If so, what would be needed?
I have my motor out right now and yeah it was a PITA to change the mounts when I bought the truck.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
05-21-2019, 02:32 PM | #7 | |
The attached pic is from another group and is a '79 C10 - wonder what it would take to convert to this style? |
05-21-2019, 05:33 PM | #8 |
I have a set that came off a 67 with a 350 in it if someone is interested in them I can list them in the parts section for sale .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
05-21-2019, 05:51 PM | #9 |
05-21-2019, 06:03 PM | #10 |
Single bolt ,They came on a unfinished project truck small block with headers I bought a while back .I sold the engine to a member here and the frame locally .
05-21-2019, 06:07 PM | #11 | |
Thanks! |
05-21-2019, 07:58 PM | #12 |
Can you show a picture of the standard and single bolt style that you guys are talking about, side by side? I would like to know what you're talking about.
