01-14-2017, 10:53 PM | #1 |
Clutch Fan
Is there a good aftermarket clutch fan for my 1971 GMC 4X4 with a 350 in it?
01-14-2017, 11:17 PM | #2 |
Re: Clutch Fan
four seasons makes great one look on summit
01-15-2017, 12:07 AM | #3 |
20' Daredevil (Ret)
Re: Clutch Fan
Quite a few actually.... To be clear, do you need a clutch fan (fan blades), or a fan clutch (what the fan blades attach to)?
Assuming it's the clutch unit, your '71 is probably like my '72 K20. Factory 7-blade fan with a 2 1/2" pitch. If so, it should use a HD clutch like the factory one. HD ones have fins across the front, and standard-duty ones just have a ring of fins around the perimeter. A few months ago I replaced my leaking OEM fan clutch with one from my local NAPA store. Made in Texas by Four Seasons, NAPA p/n 271303. It's a perfect fit. Oddly, most aftermarket outlets don't list a HD unit for my truck. We had to look up a mid-to-late Seventies K30 to find the correct HD unit. Good info here including differences between standard & HD,if you're interested: http://www.haydenauto.com/featured%2...s/content.aspx
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
01-15-2017, 01:51 AM | #4 |
Re: Clutch Fan
I should of been more specific, I need the Fan w/6 or 7 blades that will take a thermal clutch attached to it. I know I can get the clutch itself but can't find the fan.
01-15-2017, 01:53 AM | #5 |
Re: Clutch Fan
Stocker, thanks for the NAPA part# number also, I will check that one out.
01-15-2017, 01:55 AM | #6 |
20' Daredevil (Ret)
Re: Clutch Fan
Forgot to add the Four Seasons part number to the above NAPA clutch I bought.... it's #2747.
01-15-2017, 01:59 AM | #7 |
20' Daredevil (Ret)
Re: Clutch Fan
There's this but it's kinda spendy http://www.speedwaymotors.com/Dynaco...FQ9EfgodlrQB-A
A bit cheaper http://www.classicindustries.com/pro...arts/k193.html Good luck, I hope ya find one that works for you. Local boneyards all cleaned out?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 01-15-2017 at 02:06 AM. |
01-15-2017, 02:07 AM | #8 |
Re: Clutch Fan
Stocker, Also I think the 4 Seasons part#number is 36956, NAPA uses their own number I think, but I could be wrong.
01-15-2017, 02:10 AM | #9 |
20' Daredevil (Ret)
Re: Clutch Fan
That's very possible.... I just got the p/n off the box it came in. It also had NAPA p/n 271303.
01-15-2017, 02:47 AM | #10 |
Re: Clutch Fan
Thanks for the info Stocker!
01-15-2017, 01:37 PM | #11 |
Re: Clutch Fan
I bought this one from Summit a few weeks ago https://m.summitracing.com/parts/der-17118/none/images. I'm happy with it
01-15-2017, 01:55 PM | #12 |
Re: Clutch Fan
Kelz702, Thanks for the info!
01-15-2017, 02:17 PM | #13 |
All about them K’s
Re: Clutch Fan
OE fans come up for sale on the parts board from time to time as well.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
02-02-2017, 06:07 PM | #14 |
Re: Clutch Fan
Hey guys, not to hijack this thread, but it's exactly the type of info I'm looking for. Couple questions, especially for you, Stocker, since our trucks are pretty similar:
1) Am I correct in assuming that the stock 7-blade fixed fan will accept a clutch unit? EDIT FOR FUTURE SEARCHES: Nope. 2) Stocker, how far does your fan clutch sit from the radiator? I've read elsewhere that a thermostatic clutch needs to be very close (like only 1-2") to the radiator in order to heat up properly and actually disengage. Want to change out my fixed fan (for HWY MPG) but as you all probably know the 4x4 engine sits further back and I want the clutch to actually work. My fixed fan is several inches from the radiator, essentially sitting just inside the shroud. Thanks everyone for any info.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED Last edited by joeydurango; 02-02-2017 at 08:08 PM. Reason: Answered my own question |
02-02-2017, 06:09 PM | #15 |
Re: Clutch Fan
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
02-02-2017, 07:14 PM | #16 |
All about them K’s
Re: Clutch Fan
I don't believe that the 4x4 clutches sit that close to the radiator. Mine doesn't I know that much.
02-02-2017, 07:17 PM | #17 |
Re: Clutch Fan
Thanks for the reply. Kind of figured that too... but then I'm wondering if it actually warms up and disengages as it's supposed to?
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
02-02-2017, 08:01 PM | #18 | |
20' Daredevil (Ret)
Re: Clutch Fan
The Hayden link in post #3 explains when different type clutches engage / release etc. Not sure just how you'd actually check it, though.... depends on what problems you have, if any.
02-02-2017, 08:10 PM | #19 |
Re: Clutch Fan
Thanks Mike. Since yours apparently works okay I'll go with that Napa clutch PN you used, and decide on a fan to match.
02-02-2017, 09:57 PM | #20 |
All about them K’s
Re: Clutch Fan
My replacement is a napa as well and it does work.
