Old 06-21-2018, 02:29 PM   #1
Sharptrans
67 frame question
Hi,
Will a frame from a 67 SWB c10 fit using a 1970 cab? Any differences between a 67 to a 70 frame. Any advise would be great. I guess a better way to ask the question is will a 67 chassis SWB work on my 1970 SWB? Thx
Sharptrans is offline   Reply With Quote
Old 06-21-2018, 02:41 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: 67 frame question
Yes , If you have PS in the 70 you may have to dimple the 67 frame to fit the power steering box to the frame , No big deal .
Old 06-21-2018, 03:48 PM   #3
68 TT
Still plays with trucks
68 TT's Avatar
The holes in the top of the core support brackets were smaller in diameter on my 67 C10 vs those on my 69 C10 so the poly bushings didn't retrofit without a little metal work.
The width of the frame rail top flange near the engine mounts was wider on the 67 vs my 69 also. It caused header tube clearance issues using the same engine, trans, crossmember, frame mounts and headers is why I figured this out. It was only about a 1/4" but with a big block and 2" tube headers every little bit counts.
As noted above there are non-power steering versions of the 67 frame also that require extra effort to install power steering onto them.
In addition I have come across later (68 & 69 for sure) manual steering trucks that the core support brackets were not clearanced for a power steering gear box even though the frame was designed to take one. Required about 1/4" to be taken off one corner of the core support bracket so the gear box could mount up flush without bending the core support bracket.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 06-21-2018, 07:25 PM   #4
Ruscal
You may want to check with dmv to see what is necessary for numbers.
Russ
RC
Ruscal is offline   Reply With Quote
Old 06-21-2018, 08:40 PM   #5
Sharptrans
Thanks For the input. I thought I had A lead on a clean frame but it fell through, so still looking for a 67-72 frame in good shape. I don't mind paying for a good quality piece.
