Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-23-2015, 04:49 PM   #101
hemi43
hemi43's Avatar
Re: Hemi's 70 Blazer build
I'll be covering the floor with sound deadener (Peel&Seal), then carpet without the jute backing. I made my own roll bar and had it mandrel bent.
hemi43 is offline   Reply With Quote
Old 11-23-2015, 05:20 PM   #102
Chad22873
Chad22873's Avatar
I have read about peel and seal somewhere. Perhaps in one of your posts. Where do you get it?
Chad22873 is offline   Reply With Quote
Old 11-23-2015, 07:32 PM   #103
hemi43
hemi43's Avatar
I live in Canada, so I get it from a roofing supply house. I think Home Depot in the US sells it.
Old 11-27-2015, 05:51 PM   #104
hemi43
hemi43's Avatar
Engine bay is starting to fill up. So far I've had zero clearance issues, and it looks like it belongs there.
Old 11-27-2015, 06:28 PM   #105
grillzy
that looks great!
grillzy is offline   Reply With Quote
Old 11-29-2015, 12:43 PM   #106
mx289
mx289's Avatar
Good progress.Looks great.
I like the paint too.
What color interior where you thinking ?
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 11-29-2015, 11:19 PM   #107
hemi43
hemi43's Avatar
Thanks for the comment.
Seats and carpeting will be black.
Old 12-09-2015, 10:46 AM   #108
Wasted Income
Boosted Member
Wasted Income's Avatar
OUTSTANDING work! Very awesome.
I am interested in building a plasma table like that...can you point me in the right direction?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 12-13-2015, 11:17 AM   #109
hemi43
hemi43's Avatar
Go to http://candcnc.com/
for the electronics. The table will have to be built with whatever you can afford or scrounge. The most expensive part will the the linear bearings. Try to find some used ones. Another way of getting the table is to purchase an old one with outdated electronics and rebuild it.
Old 12-17-2015, 04:33 PM   #110
hemi43
hemi43's Avatar
Doesn't look like much progress, but I haven't stopped working on the Blazer. Finally got all the wiring done which took forever. I hate wiring !! Got the Dakota Digital dash installed too.
Fender and doors were temporarily installed so that the body mounts could be shimmed and tightened. I'm real happy with the door fits.The new grille was also fitted. It's real thin compared to the original.
Go my rad core this morning from Howe racing, so will be fabbing the tanks hopefully this weekend. Once it's installed, I'll be able to fire up the engine.
Old 12-17-2015, 06:53 PM   #111
grillzy
I can see the end soon!
Old 12-17-2015, 07:06 PM   #112
hemi43
hemi43's Avatar
Me too !! Definitely went faster than I thought. Having Bill's Trucks so close made all the difference!!
Old 12-18-2015, 08:09 AM   #113
jaros44sr
jaros44sr's Avatar
Looks great, nice progress. Where did you get the steering wheel mounting hub. Mine is a very old design, and the horn button keeps falling off
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-23-2015, 11:05 AM   #114
hemi43
hemi43's Avatar
If your horn button is falling off, you may have the mounting ring clocked wrong. Remove the button, and you'll see that it will only go on one way on the ring.You may need to rotate the mounting ring 1 or 2 holes.
I got the rad done and installed. I plasma cut the tanks and they fit perfect. I only have about $200 in total to build the rad so it was worth a bit of time and effort considering buying a comparable unit would be almost $500.
I also got the AC lines installed. I haven't put the 134a in yet just in case things have to come apart. I did however evacuate the system and seems to hold a steady vacuum.
Hopefully will get it fired up next week.
Wishing all of you a Merry Christmas and a Happy New Year !!
Dan
Old 12-23-2015, 12:35 PM   #115
IronCanine
I'm trying....
IronCanine's Avatar
Just outstanding workmanship Dan. Continuing to look great. Getting excited with you. Good luck on the key-turn....love that 70 grille!
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 12-24-2015, 09:09 AM   #116
wannabefastcrf
Maybe I missed it. Who did your harness and is it new or a reworked stock harness
wannabefastcrf is offline   Reply With Quote
Old 12-24-2015, 11:27 AM   #117
hemi43
hemi43's Avatar
I did my own harness. Just a reworked stock item, and it's really quite simple to do. This web site will take you step by step on how to do it.http://www.lt1swap.com/
Having a wiring schematic of the donor vehicle is a must also especially if you want to run all the emission components.
Old 12-24-2015, 01:25 PM   #118
Chad22873
Chad22873's Avatar
Do you have any specs for the roll bar that you built?
Old 12-24-2015, 02:49 PM   #119
hemi43
hemi43's Avatar
I have a couple .DXF drawings of it. You may want to wait till I get the driver's seat installed before copying it. I designed it to fit under the Softopper, but am concerned about having the seat belt mounting point too close to my head. Time will tell if I have to modify it or move it back a bit.
It was made from 2 1/2 dia 1/8 wall tubing with a CLR of 5".
Dan
Old 12-26-2015, 04:12 PM   #120
Sacramento70
Blazer Fanatic
Sacramento70's Avatar
Man, Super cool build you got going on. i wish i was there with ya to learn from your skills. Ive only seen one 70 blazer in med. gold and thats mine. You found the twin!
1970 Chevy blazer
Sacramento70 is offline   Reply With Quote
Old 12-27-2015, 09:38 AM   #121
hemi43
hemi43's Avatar
It's alive !!
https://youtu.be/BcFMoWSBBdk
Old 12-29-2015, 07:09 PM   #122
grillzy
Sounds great! Perfect start
Old 12-30-2015, 01:00 AM   #123
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice!
DeadheadNM is online now   Reply With Quote
Old 12-30-2015, 03:03 PM   #124
IronCanine
I'm trying....
IronCanine's Avatar
Big step...sounds sweet. Congrats.
Old 12-30-2015, 04:42 PM   #125
hemi43
hemi43's Avatar
Thanks Guys !! Definitely a huge hurdle overcome. Getting kinda burned out working on it and looking forward to the end.
