05-09-2012, 11:36 AM | #1 |
Which Cummins to put into my truck?
I am seriously thinking of putting a Cummins into my 79 1 ton 2wd CCSWB project. I definatly want an automatic trans with overdrive. What I would like is input on what you all like and any other helpful info. Id like to keep away from all the electronics if I can. Plan to use the truck for everyday driving and towing.
05-09-2012, 11:45 AM | #2 |
Re: Which Cummins to put into my truck?
94-98 is best for power, they have the p-pump. 89-93 has the ve which gets 1-2 mpg better supposedly.
for auto you'll want a 94-95 47RH. only electrical on it is a 12v switch for overdrive and lockup, which you can control with two switches, or use pressure switches on the trans to do it automatically.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
05-09-2012, 02:07 PM | #3 |
Are the 89-93 and the 94-98 the same except for the pumps?
05-09-2012, 06:19 PM | #4 |
i think that the cummins wiring is the ezest out there. if you can get a motor with the ecm that is a runner on stand you will see it is only i few wires that you need to run. i am thinking about runnning a commin rail in my 85 k30. just for something diff
05-09-2012, 10:57 PM | #5 |
I am running a 96 p-pump in my 84 only wire you have to have is to the starter. I ran a fuel shutoff relay to operate the electric solenoid but fuel shutoff can be controlled by a cable. I run a 5 speed trans so am no help there.
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
05-09-2012, 11:36 PM | #6 |
I say 4bt but I guess I am just partial to them since that is what I have in my truck. Not as easy to come by as the 5.9 but quite a bit lighter and fits in the engine bays nice. We have done both 5.9 and 4bts conversions. My 2wd CCSB seems pretty well balanced as far as weight goes to and it rides really nice.
05-10-2012, 12:18 AM | #7 |
Is that converted to 1/2 ton as well??
05-10-2012, 01:17 AM | #8 |
A 4bt will be better as a driver and can handle most smaller loads like a 1/2 ton could pull.If your gonna use it as a 1ton i would get a 12 valve then.On the trans a dodge one will be easier but you might have to mess with the trans crossmember and have a driveshaft made.The pricey way with a auto is a adapter kit and run a 4l80 with a controler.You can get the motor mounts from http://www.tndieselpower.com/site/products-page/ or http://www.autoworldmt.com/Page_11.html has a lot of nice stuff.
05-10-2012, 01:26 AM | #9 |
gets board easy.......
Ive had a hard time looking for a Cummins lately. Not many out there.
Are you having any luck finding in your area? Posted via Mobile Device |
05-10-2012, 09:26 AM | #10 |
05-10-2012, 10:02 AM | #11 |
Is the 4l80e a better trans than the 47rh?
I only know of 1 right now for sale. I beleive its an 94 with an auto trans and transfer case for $1200. Its suppose to have 87,000 miles on it. Something is wrong with the trans though. Thanks for the input. |
05-10-2012, 10:24 AM | #12 | ||
The 94-98.5 Cummins have P-pumps on them. The pump can supply enough fuel for roughly 1000 hp. The huge power potential is the big advantage with these engines. It can make enough power to rip apart the rest of the drive train in no time. Quote:
Not really. A 6BT Cummins will rip it apart just as fast as the 47rh. If you have to have an automatic and want some reliability, look into having the 47rh upgraded. It'll be very expensive (around $6k) but worth it IMO.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift Last edited by Edahall; 05-10-2012 at 10:36 AM. |
05-10-2012, 10:27 AM | #13 |
I have had a 4l80e behind my Cummins for 5 years with no issue's.
05-10-2012, 10:36 AM | #14 |
05-10-2012, 10:44 AM | #15 |
It is behind a 4bt . Not the fastest truck in stock form. It tops out at about 85mph but will pull any hill at 65 so it is good enough for me. I get 26 highway with 3.73 gears.
05-10-2012, 12:09 PM | #16 |
Just curious - why not just by a RAM truck with a Cummins already installed?
05-10-2012, 12:13 PM | #17 |
everyone talking about the 12 valve p pump cummins... why not a 24 valve with the p pump conversion? would that not make more power?
Cole. 1967 GMC c15 1991 k2500 2005 2500hd Duramax |
05-10-2012, 02:19 PM | #18 |
P-pump conversion is done on a 24 valve to make more power. You would think 24 over 12 valve would make more power however, with forced induction, there is not much advantage in terms of power with having more valves. That said, I would be careful with a 24 valve block. They are known for the blocks cracking. Do a good on "53 block crack" to find more about it.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
05-10-2012, 02:20 PM | #19 |
"Love the engine, hate the truck".
05-10-2012, 08:12 PM | #20 |
How about an Allison. I imagine it would be pretty costly.
05-10-2012, 08:18 PM | #21 | |||
Right now I got about $1200 in my complete swap but I still have the Dana 70 Front and Dana 80 Rear Axle that should cover part of that expense. I parted the rest of the Dodge and crushed all that was left.
05-10-2012, 09:09 PM | #22 |
6>8 Plugless........
Cause who wants a dang dudge? I work on them all the time and they are rattle traps. Great power train and drive train, crap body!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-10-2012, 09:12 PM | #23 | |
As far as the heads, yes the 24v heads flow more air in stock trim and tend to make more power on mild builds. Once you hog out a 12v head, it's hard to beat them though. I also agree the 47rh is the auto trans to run behind these.
05-10-2012, 09:23 PM | #24 |
if i where going to spend the money on a allison 1000 and stand alone.......id just get a duramax allison combo. its not that much more wiring.
2004 2500 hd dmax cc 4x4 2008 saturn aura xr 1966 buick gran sport 1984 k20 |
05-10-2012, 09:25 PM | #25 | |
CHEVY ONLY |
