Old 10-02-2018, 12:13 PM   #351
1972RedNeck
1972RedNeck's Avatar
Re: My 56 6bt 4X4 build.
Originally Posted by 6BT 56 View Post
You are correct. The more I think abt it the more I'm quite happy with how everything sits on the original frame body wise. I think the route of my problem is that the 56 front springs are held at the rear. With shackle at front . Every other push pull steering truck is mounted at front of spring and shackle at rear. I think my push pull and the fact that the leaf is mounted at the back is my trouble . Just wondering if I should update to newer leaf springs and change mounts around or should I try crossover steering ?
While crossover steering is the way to go, I think your steering/handling problems come from the steering box and possible caster angle.
RedHead steering gear is the only way to go for a first gen Dodge box (any steering gear really).
What is you caster set at? You are using the Dodge D60 front, right? If so, I am willing to bet your caster angle is in the 1 to 2 range. Get it up to at least 4 if not 6 to 8.
Another important thing is to use Dana/Spicer parts only in the kingpins - On my current 1st gen Dodge, I rebuilt the kingpins with NAPA cones and springs - truck drove terrible. Finally bought OEM parts and it was much better.
Turns out the NAPA cones were way softer so they were grabbing and galling and wouldn't let the wheels "self steer".
As for the leaf spring setup, my '66 F250 is pined in the back, shackle (actually slipper) int he front. I have been known to regularly cruise at 90 to 100 MPH. Drives great.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 10-04-2018, 12:01 PM   #352
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
The OBS Fords (88-97) use the front shackle in the front and they drive ok. But it is a lot better when you put the shackle in the rear and even better when you put a longer leaf spring up front. Granted you won't get the coil spring ride quality of a 05 up, bu it is a big improvement.
If you go cross over, make sure to put a panhard or track bar on the front axle.
Ryan
1976 K30 CC SWB Build Thread
Old 10-04-2018, 09:28 PM   #353
6BT 56
6BT 56's Avatar
Ya I'd like to change front springs. I keep coming to the realization that if I buy new front springs, get some sort of perches and shackle mount money wise I'm close to buying a bunch of 4 link parts . Was thinking abt arms like this
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15.
2002 sub 2500 4X4. Needs a D Max.
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 10-05-2018, 06:32 PM   #354
Dieselwrencher
You're going down a rabbit hole.....
Ryan
4x4, cummins, napco
Copyright ©2000 - 2018, vBulletin Solutions Inc.
