10-05-2019, 05:17 PM | #1 |
NL2 auxiliary fuel tank parts
Wiring harness, modified for toggle switch $30 shipped
Fuel filler cover, little rust at the bottom $45 shipped...Sold Fuel filler neck with original gas cap, $50 shipped Wiring harness with factory switch, $75 shipped...Sold Valves with plastic bolt spacers, $30ea shipped Plastic trim plate, one small crack, $35 shipped...Sold Combined shipping discount could be huge.... Last edited by randy500; 10-15-2019 at 03:50 PM. |
10-05-2019, 07:15 PM | #2 |
Carpe manana
Re: NL2 auxiliary fuel tank parts
Interested in the oem harness/oem switch - working switch? Knob and bezel included?
Also interested in the trim plate pending pics. Thanks.
10-05-2019, 07:50 PM | #3 |
I opened up the switch, cleaned it to bright copper contacts, lubed with white lithium grease and close dit up, works great now.
Wiring harness has cut on grommet where someone ran a wire, still has crimped on wire protector at tank, i had to pull the wire out of the ring terminal to remove it, the nut was too rusty to remove. The other wore harness the grommet is not cut, you could crimp on some packard terminals and insert the wires into the plastic switch connector |
10-05-2019, 07:51 PM | #4 |
Harness grommet cut
10-05-2019, 07:51 PM | #5 |
Other harness
10-05-2019, 07:53 PM | #6 |
Filler neck cover
10-05-2019, 07:56 PM | #7 |
Filler neck with original fuel cap.
10-06-2019, 07:53 AM | #8 |
Is this off a 72? Would it be a vented cap? I would be interested in all the fuel filler pieces and if possible Maby the cutouts around box where the filler goes thru. I need a vented system for a 67 though.
10-06-2019, 09:19 AM | #9 |
Carpe manana
Thanks Randy. I’ll take the plate.
If no takers for the harness with the switch I would take just the switch.
10-06-2019, 11:21 AM | #10 |
10-06-2019, 11:27 AM | #11 | |
I can cut the bed for templates from my 72 chev k20 with NL2, $30 for the cut plus whatever shipping is...do you have a US shipping address? |
10-06-2019, 11:34 AM | #12 |
I do have a US address. So this would use the same fuel grommet and fuel cap as the 67 70 trucks? Could you get me a few more pictures of this setup?
10-06-2019, 12:29 PM | #13 | |
The fuel cap is 72. Pictures coming. |
10-06-2019, 12:41 PM | #14 |
Nothing specific. It has a vent tube for filling correct? I can't see it in the picture. Just want to make sure I can use these for what I'm trying to do.
10-06-2019, 01:04 PM | #15 |
More pics, you would get the bed cut from the green truck.
The filler neck has an overflow tube, the tank would have the vent tube. Same as any...the vents are always in the tanks. |
10-06-2019, 01:30 PM | #16 |
Another picture
10-06-2019, 02:11 PM | #17 |
Carpe manana
Sounds good thanks. I’ll take it and send balance here ASAP.
10-06-2019, 02:18 PM | #18 |
I got the money Pete, its packaged up, will print a label later and send tracking, thank you.
I see now....your sending the remainder for the switch too....i will get it re packaged for you. Last edited by randy500; 10-06-2019 at 02:27 PM. |
10-06-2019, 02:45 PM | #19 |
Carpe manana
Yessir. Just sent the balance. Thanks again.
10-06-2019, 04:16 PM | #20 |
Thanks for the pics. I am going to pass at this moment as I might try doing something more like the burbs have.
10-12-2019, 03:40 PM | #21 |
I will take the fuel filler neck. PM sent. Thanks, Dan
10-12-2019, 06:30 PM | #22 |
10-12-2019, 11:27 PM | #23 |
Excellent! Thank you! Dan
10-13-2019, 04:01 PM | #24 |
Ttt
10-15-2019, 03:50 PM | #25 |
Ttt
