Old 10-05-2019, 05:17 PM   #1
randy500
NL2 auxiliary fuel tank parts
Wiring harness, modified for toggle switch $30 shipped
Fuel filler cover, little rust at the bottom $45 shipped...Sold
Fuel filler neck with original gas cap, $50 shipped
Wiring harness with factory switch, $75 shipped...Sold
Valves with plastic bolt spacers, $30ea shipped
Plastic trim plate, one small crack, $35 shipped...Sold
Combined shipping discount could be huge....
randy500 is offline   Reply With Quote
Old 10-05-2019, 07:15 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: NL2 auxiliary fuel tank parts
Interested in the oem harness/oem switch - working switch? Knob and bezel included?
Also interested in the trim plate pending pics.
Thanks.
Old 10-05-2019, 07:50 PM   #3
randy500
I opened up the switch, cleaned it to bright copper contacts, lubed with white lithium grease and close dit up, works great now.
Wiring harness has cut on grommet where someone ran a wire, still has crimped on wire protector at tank, i had to pull the wire out of the ring terminal to remove it, the nut was too rusty to remove.
The other wore harness the grommet is not cut, you could crimp on some packard terminals and insert the wires into the plastic switch connector
Old 10-05-2019, 07:51 PM   #4
randy500
Harness grommet cut
Old 10-05-2019, 07:51 PM   #5
randy500
Other harness
Old 10-05-2019, 07:53 PM   #6
randy500
Filler neck cover
Old 10-05-2019, 07:56 PM   #7
randy500
Filler neck with original fuel cap.
Old 10-06-2019, 07:53 AM   #8
chewychevy67
Is this off a 72? Would it be a vented cap? I would be interested in all the fuel filler pieces and if possible Maby the cutouts around box where the filler goes thru. I need a vented system for a 67 though.
chewychevy67 is offline   Reply With Quote
Old 10-06-2019, 09:19 AM   #9
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Randy. I’ll take the plate.
If no takers for the harness with the switch I would take just the switch.
Old 10-06-2019, 11:21 AM   #10
randy500
I can do $80 shipped on the switch and plate if that works for you.
Old 10-06-2019, 11:27 AM   #11
randy500
It is a 72, The cap is standard 72 eec type (smaller opening) so im sure its vented. These k20’s have the older large opening non eec cap on the cab tank and the smaller opening cap on the aux tank. Kind odd i think.
I can cut the bed for templates from my 72 chev k20 with NL2, $30 for the cut plus whatever shipping is...do you have a US shipping address?
Old 10-06-2019, 11:34 AM   #12
chewychevy67
I do have a US address. So this would use the same fuel grommet and fuel cap as the 67 70 trucks? Could you get me a few more pictures of this setup?
Old 10-06-2019, 12:29 PM   #13
randy500
Any specific pictures needed? The grommet looks similar to the earlier tank grommet, i dont know if its the same or not.
The fuel cap is 72. Pictures coming.
Old 10-06-2019, 12:41 PM   #14
chewychevy67
Nothing specific. It has a vent tube for filling correct? I can't see it in the picture. Just want to make sure I can use these for what I'm trying to do.
Old 10-06-2019, 01:04 PM   #15
randy500
More pics, you would get the bed cut from the green truck.
The filler neck has an overflow tube, the tank would have the vent tube.
Same as any...the vents are always in the tanks.
Old 10-06-2019, 01:30 PM   #16
randy500
Another picture
Old 10-06-2019, 02:11 PM   #17
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Sounds good thanks. I’ll take it and send balance here ASAP.
Old 10-06-2019, 02:18 PM   #18
randy500
I got the money Pete, its packaged up, will print a label later and send tracking, thank you.
I see now....your sending the remainder for the switch too....i will get it re packaged for you.
Old 10-06-2019, 02:45 PM   #19
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Yessir. Just sent the balance. Thanks again.
Old 10-06-2019, 04:16 PM   #20
chewychevy67
Thanks for the pics. I am going to pass at this moment as I might try doing something more like the burbs have.
Old 10-12-2019, 03:40 PM   #21
karphan
karphan's Avatar
I will take the fuel filler neck. PM sent. Thanks, Dan
karphan is offline   Reply With Quote
Old 10-12-2019, 06:30 PM   #22
randy500
PM replied, money recieved, i need your address......I see your address via PM, thank you.
Old 10-12-2019, 11:27 PM   #23
karphan
karphan's Avatar
Excellent! Thank you! Dan
Old 10-13-2019, 04:01 PM   #24
randy500
Ttt
Old 10-15-2019, 03:50 PM   #25
randy500
Ttt
