Old 05-21-2017, 08:09 PM   #1
HBlue
78 Silverado- seal access cutouts in door
I finally finished rebuilding the vent window and replacing the window glass on the passenger side door.
How do you guys seal the access cutouts in the door? There was a piece of paper stuck on with a tar like substance, but it has disintegrated. I have something to go around the bottom and sides of the door panel.
HBlue is offline   Reply With Quote
Old 05-22-2017, 02:17 AM   #2
1981Stepside
1981Stepside's Avatar
Re: 78 Silverado- seal access cutouts in door
I had some leftover clear plastic vapour barrier sheeting that I stuck on neatly with some gorilla tape
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 05-23-2017, 10:26 AM   #3
Bluestep
I used the thin foam that is made for putting under laminate flooring and attached it with Gorilla tape originally, and then that aluminum ducting tape. (some of the Gorilla tape let go) The foam helps with sound deadening.
Bluestep is offline   Reply With Quote
