Old 03-27-2010, 05:30 PM   #1
jlolson
jlolson's Avatar
Hood to cowl seal and alignment
Hello all,
I just installed a new hood to cowl seal. The new seal is standing straight up and the old seal rolled over the cowl screws. Which is correct?
I also am noticing my hood passenger side is sticking up in the back and getting worse. Is this a bad hinge or an alignment issue?
Thanks in advance,
jlolson is offline   Reply With Quote
Old 03-27-2010, 05:34 PM   #2
mbgmike
Re: Hood to cowl seal and alignment
Originally Posted by jlolson View Post
Hello all,
Thanks in advance,
Old one was correct. The replacements are the same. You can still buy them from GM
mbgmike is offline   Reply With Quote
Old 03-27-2010, 05:50 PM   #3
Texasbigblock
Texasbigblock's Avatar
i had/ have the same exact problem with the one from LMC....
-Scott-
1970 C10 shortbed 396
1969 C30 dually flatbed "Vidalia"
Texasbigblock is offline   Reply With Quote
Old 03-27-2010, 05:51 PM   #4
jlolson
jlolson's Avatar
Ah man. Really? What should I do then, buy another one?
Old 03-27-2010, 05:55 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
They take a little bit to break in. You can adjust your hood by loosening the bolts to the fender, pushing up on the hood when it's open and retightening the bolts.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-27-2010, 06:35 PM   #6
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Thumbs up Re: Hood to cowl seal and alignment
That is how mine looked when I first put it on it stuck straight up, but now it is rolled over like the old one was. It's fine.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 03-27-2010, 06:47 PM   #7
mbgmike
The quality ones are already folded like the factory. Plus if you do purchase one from GM you don't have to do the little cut outs. If you Purchase Quality repro you will have to cut them.
Sounds like the other mentioned company was selling a cheap piece of flat rubber.
Old 03-27-2010, 07:03 PM   #8
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Hey I was installing an aftermarket one today too, but mine seemed to sit down a bit better and it has the cutouts. My issue is that there seems to be a big gap between the cowl and bottom (where seal goes). On each end where there is no seal there's a big gap. Is there supposed to be something else in there that I'm missing?
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 03-27-2010, 07:34 PM   #9
jlolson
jlolson's Avatar
I think the gap is fine. Mine is the same.
Old 03-28-2010, 02:19 PM   #10
jlolson
jlolson's Avatar
I had no luck finding one from GM. Is anyone aware of where I could purchase the correct seal online or otherwise?
This LMC part is not going ot work, half of it folds over when the hood is close, the other half pinches and folds in. I can't believe LMC would sell this thing. I've got it folder over with painters tape now so I can close my hood. Classy.
Old 03-28-2010, 02:35 PM   #11
mbgmike
UH last time I looked we sell them but you can buy them here
http://www.gmpartsdirect.com/restora...tocategory.cfm
We have them in stock to
Old 03-28-2010, 03:23 PM   #12
kelsfine69
18 Till I Die
kelsfine69's Avatar
Yes the repo ones are L shaped and the GM ones are bent back. I had this on for 2 years now and it still does not lay flat. My hood also gets pushed up because of this so I went and bought a GM one. I dont have the part Number but the 2nd pic is Gm correct. I will get around to instaling it this spring...
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-28-2010, 05:43 PM   #13
mbgmike
They make the repro ones just like Gm its just these guys aren't buying them. The repros are just like GM except the little squares for the screws are not cut out and the GM have a few little ribs in them. Also a little lip on the flat edge. The other repros are not even close to a reproduction.
Here is a picture of a repro not the flat rubber stuff
Old 03-28-2010, 05:45 PM   #14
mbgmike
You install the rubber on top of the cowl not between the cowl and body.OOPS
Old 03-29-2010, 05:49 PM   #15
culp7
HickTown
culp7's Avatar
does anyone have a direct link to the GM made ones???
1993 Ford Mustang Vert w/ 2.3
1969 Chevy C/10 w/350
1968 Chevy C-20 w/250
1976 Dodge Aspen W/ 225
2000 Toyota Tundra w/4.7
1987 Dodge Ram D-100 w/360
255/70-15
___________
(oo)══╬══(oo)
culp7 is offline   Reply With Quote
Old 07-28-2013, 08:40 AM   #16
richards72chevy
richards72chevy's Avatar
I guess I should have done some research on here before I bought mine.Got one from lmc as well.It fits so badly its letting rain water on my cap and coil causing a no start.
richards72chevy is offline   Reply With Quote
Old 04-13-2015, 10:05 PM   #17
Pickup69er
I bought the cowl hood seal from LMC and wrestled with many of the issues mentioned here. My final solution (factory correct or not) was to fit the ribbed/lipped portion of the 90˚ rubber seal under the cowl, i.e., between the cowl and the body. When the hood drops, the rubber does a natural bend and seals against the top inside edge the hood.
Pickup69er is offline   Reply With Quote
Old 10-18-2015, 05:05 PM   #18
Redline novdog
Redline novdog's Avatar
I am in the middle of doing a screen under the cowl and the seal is shot so if anyone has a GM number please post it! FYI my seal was between the cowl and cab.
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 10-18-2015, 07:55 PM   #19
Redline novdog
Help!
Old 10-21-2015, 10:09 PM   #20
moon
moon's Avatar
Bump -----> Mine didn't have a cowel seal when I bought it... never knew it was supposed to, which explains a 'couple things. I am also having difficulty finding a source other than LMC.
1970 CST long bed Fleetside
moon is offline   Reply With Quote
Old 10-21-2015, 10:16 PM   #21
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
About halfway down this page. $9.99 for the seal.
http://www.classicheartbeat.com/rubb...atherstrip.htm
I bought this seal from Classic Heartbeat (site sponsor) and it fit just fine in my 1972 GMC.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 10-22-2015, 08:39 PM   #22
Redline novdog
Ordered mine tonight from Classic Heartbeat. The freaking shipping was almost twice the price of the seal! Really! Anyway better be good. I'll let you all know.
Old 10-22-2015, 09:36 PM   #23
jondancer
Subscribed, I need this seal too
jondancer is offline   Reply With Quote
Old 10-22-2015, 09:42 PM   #24
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I'd like to know if it works too. I installed one from LMC on mine and ended up removing it. It's just another thing on the list to finish.
Ryan
1969 Chevy milk truck
Old 10-26-2015, 06:33 PM   #25
Redline novdog
Have not got it yet but Wes from Classic Heartbeat e-mailed me that I ordered 2,my mistake and I don't know where else you would get that kind of service!
