06-26-2011, 02:01 PM | #1 |
tilt column swap question
I picked this up from another member months ago and just now starting to think about the swap. Here is my question, how do I make this work? My truck is a 83 scottsdale without intermiten wipers but does have cruise control. the wiper switch is on the dash. The column I got is set up for intermitten wipers and the switch is on the column with the cruise control stuff all on one lever. What do i have to do to make it work? also, got it without keys, how do I change the lock cylinder without the key?
Anthony |
06-26-2011, 08:15 PM | #2 |
Laid back freak
Re: tilt column swap question
83 was the last year of the trucks with the wiper switch on the dash and in 84 they went to the column with everything from the CC to the wipers to the high beam switch.I think your better off looking for a 83 and down column to make it alot easier to install.I found 1 from a 82 GMC high sierra in a junkyard for 50.00. I had to have it rebuilt for 150.00.But for 200.00 its tight,its correct and i dont have to worry about any problems hooking it up and not working..
thanks Pat
1980 chevy c10 step side restomod, 1970 cougar convertible 1 OF 24 ever built: 2014 Hyundai Tucson limited (daily driver). Last edited by 80stepsideguy; 06-26-2011 at 08:17 PM. |
06-26-2011, 09:53 PM | #3 |
Robert Olson Transport
as to pulling apart the column to change the ignition switch its pretty simple with the right tools... pull off the wheel use the compressor to compress the piece under the wheel.. remove the retaining clip, and once you slide out the turn signal switch there are pins or screws that hold in the ignition key switch
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
06-27-2011, 12:12 AM | #4 | ||
Anthony |
