04-19-2017, 10:16 PM | #1 |
Question about rear view temp/compass mirror from donor Yukon
I'm stripping a yukon I bought for my swap and thought the mirror would be cool to have too. I know there's a temp sensor but what about the compass? Is that built in?
04-19-2017, 10:56 PM | #2 |
Re: Question about rear view temp/compass mirror from donor Yukon
ANDY4639 a member here has installed them in his trucks...pm him and find out...or ask this question in the 67-72 message board
04-19-2017, 11:22 PM | #3 |
I put one of these in my truck. There was no external sensor for the compass. Just the temp sensor and power wires.
04-20-2017, 05:55 AM | #4 |
Old member
The compass is the cube behind the mirror. The senor is out on the front grille. Hot wire ground and the 2 senor wires is all you need.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-20-2017, 11:00 AM | #5 |
What year is your yukon? Cause I've been wanting to do this since i got the truck, but most that I see in the junk yards have Onstar as well
04-20-2017, 07:50 PM | #6 |
Old member
Late 90's like 98 and 99 Tahoe have just the temp & compass!
04-20-2017, 08:09 PM | #7 |
I must have seen any tahoes at the u pull it yard then. Thanks
05-03-2017, 12:17 PM | #8 |
Just installed this mirror from an 02 Silverado, no airbag lights, no map lights. Wiring was simple. 5 wires, pink(red) is 12v+ ign, black is ground, light green is suppose to go to reverse lights so it doesn't dim in reverse, but ground it if you don't want that, then black with white goes to temp sensor and dark green goes to temp sensor.
05-04-2017, 10:31 PM | #9 |
Thanks for the info and the Yukon is an 03
05-07-2017, 01:36 AM | #10 | |
05-07-2017, 08:24 AM | #11 |
I forgot about the wire that goes to the reverse lights. Mine had that also.
05-09-2017, 08:43 PM | #12 |
Old member
Here are the diagrams I have for the mirror.
Depending on what the mirror came out of will be the colors you use.
