Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 08-06-2018, 07:00 PM   #1
ScottH
ScottH's Avatar
WTB seat bottom springs
Having my seat recovered & found out several bottom springs were broken & rewelded. Would like to find some replacements. Any one with a seat or willing to remove the springs please let me know.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
2008 Corvette convertible
ScottH is offline   Reply With Quote
Old 08-06-2018, 08:21 PM   #2
jdl71
jdl71's Avatar
Re: WTB seat bottom springs
Are you talking about the long repeating "s" that runs front to back? Or the actual spring that holds you up? Sorry I don't know a better way to describe.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 08-07-2018, 12:06 AM   #3
ScottH
ScottH's Avatar
Attached is a pic of the springs, looks like they run front to back. Looks like the welding took the temper out of them, so best to replace them now.
From the looks of it I need around 7. Any help is appreciated.
Scott
Old 08-08-2018, 11:57 PM   #4
ScottH
ScottH's Avatar
still looking
Old 08-09-2018, 06:08 AM   #5
evan396
Size:  36.9 KB have one in ct if you want to come up and get it.
evan396 is offline   Reply With Quote
Old 08-09-2018, 09:48 AM   #6
ScottH
ScottH's Avatar
Thanks 4 the offer. Might be interested in picking it up, what year did it come from?
Old 08-09-2018, 08:03 PM   #7
evan396
66 k20
Old 08-09-2018, 11:37 PM   #8
ScottH
ScottH's Avatar
PM sent
Old 08-19-2018, 07:56 AM   #9
evan396
Hey Scott, I just got to the seat this mourning and it does not look like yours, this was out of an original 66 k20. Let me know what you want to do, if you don't want it I am going to scrap it.Name:  1534679604244443289036.jpg
Old 08-19-2018, 09:11 AM   #10
Grumpy old man
Grumpy old man's Avatar
I have springs and new spring clips for installing also you can add these reinforcement panels to add support , the side springs can be replicated using regular z springs when bent correctly
https://www.albrightssupply.com/Zig-...4-p/sp2024.htm
https://www.albrightssupply.com/Flex...8-p/flex18.htm
the flexolator panel you would need 60" to go across the seat bottom ,You attach them on top of the seat springs use burlap between the stock springs and flexolator then seat padding
Old 08-19-2018, 10:03 AM   #11
ScottH
ScottH's Avatar
thanks guys, the upholstery guy was able to come up with a fix.
Old 08-24-2018, 03:24 PM   #12
camrycurt
camrycurt's Avatar
Grumpy old man, do you have a set of the straight seat bottom springs that you're offering up?
If ScottH is passing on them I would be interested in talking with you about what you have.
Thanks.
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 10-02-2018, 09:37 PM   #13
VikingQueen
I'm also looking for a couple of those springs for my 65. I have 3 that are broken off where the coil connects to the frame. Any tips would be awesome.
VikingQueen is offline   Reply With Quote
