09-18-2015, 11:58 PM | #1 |
59 viking it's been awhile
Dig this out of the stickers 6-14
Made it run drive 8-14 . . After month's of life getting in the way I stayed here for inspiration....Thank you 67-72chevytrucks Brakes, Wiring,Patch floors,.... made it run again . . . . . . . . . . . now it's time for seats . Before . . these seats are from a 02 Safari going to make them work . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
09-19-2015, 12:17 AM | #2 |
Re: 59 viking it's been awhile
http://67-72chevytrucks.com/vboard/s...644706&page=17
. Drive video . https://www.youtube.com/watch?v=EraLg0LchAc . . . . . . . . . . . . . . . . .
09-19-2015, 01:23 AM | #3 |
jeeze that steering wheel looks like a nut smoosher™ but I bet you need the leverage of that big diameter.
09-19-2015, 08:09 AM | #4 |
wow, nice job.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
09-20-2015, 06:05 AM | #5 |
09-20-2015, 06:42 AM | #6 |
Nice!
Sounds pretty good to me!
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
03-26-2016, 02:15 PM | #8 |
did you end up lowering the seats a bit?
03-26-2016, 04:38 PM | #9 |
yes I did the height was too tall
so I custom made bracket and bolted them to the seat then to the truck . Stock 2002 GMC safari 3rd row seat . . . . custom brackets . .
03-26-2016, 05:13 PM | #10 |
. Yes wish I hadn't I wanted originality and to stop the rust. I just couldn't clear the rusted dash Didn't patch the hole's left the dents. They tell a story this was a work truck so I sanded the top a couple layers of rustoleum primer The black is Semi gloss black. Didn't want a shean when your driving the glare from a shinny(gossy) black dash and flat to me looks fuzzy The bottom (original gold.?) I used Hammerite Bronze....Not perfect but I did it my way and I like it . . the innerside is all Rustlok . . . .
03-26-2016, 05:28 PM | #11 |
no adjustment back and forth on the seat's.
as far back as they could go at the height I wanted. Not to far back so there up against the rear window fab'd up the brackets it feels right when your driving and having to crank the big wheel around Why.? It was cheep comfy and the backs flip forward to access behind arm rest and cup holder are Not usefull because this being a big truck if your not cranking on the steering wheel your shift the gears like a monkey with a bad itch.... (4spd with granny 1st and two spd rear axle) I probably average around 6mpg with the gears and propane setup This is no Daily driver . .........and I would have it any other way . ..........Sp . . . .
03-26-2016, 05:46 PM | #12 |
well, it's your truck so if it is right for you then it is good. if you needed to change out the seat mount you could easily find a slider at the wrecker for cheap. but.....it's your truck,it should fit YOU.
03-26-2016, 06:30 PM | #13 |
Diggin the truck, keep us updated please.
03-26-2016, 09:28 PM | #14 |
