Old 02-01-2019, 07:32 PM   #11
svr
svr's Avatar
Re: What did you do with your truck today, Part 3
Ok here's the situation, it appears somebody in this doors previous life tried to repair some damage or what ever. On the front inside corner between the hinges it either cracked and broke or they cut it on the corner. They hammered over about a1/2" of the inside skin over onto the front of the door and welded it. After i made a template from the pass side and put it onto the drivers side of the cab i found the drivers side of the cab was pushed forward about 1/4" between the hinges, not to big of a deal i got it back in shape with some blocks and a 2x4 prying on it. I cracked the paint a bit but it will be covered by the kick panel.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
