04-18-2013, 03:10 AM | #1 |
cyclic vibration
i'm finally fixing to tackle some long needed work on my truck. the biggest concern is a "cyclic" vibration at cruising speeds. its weird, as it comes & goes in a consistent pattern & doesn't seem to change noticeably with speed changes. i'm going to check driveline angles tomorrow & see where those are at. I also put new tires on not too long ago but problem was the same with the old yokohama's so ruling out tire balance issues. best way I can describe it is a wet dog shaking. it starts out light, then gets heavier, then back to light & starts over again. any ideas??
I called my stockbroker last week and asked him what I should be buying .......... he said "Canned Goods and Ammunition". |
04-18-2013, 12:12 PM | #2 |
Re: cyclic vibration
Have you greased your u joints? Or are they old, and possibly going bad.
04-18-2013, 03:04 PM | #3 |
meowMEOWmeowMEOW
If you have a 2 piece shaft, I'd say its the carrier bearing. If you pop it in nuetral and the shaking stops, its not the u joint.
When you put new tires on did they have to use a lot of weight on one wheel, possibly indicating that the wheel is out of round.
04-18-2013, 06:59 PM | #4 |
ok, a little more info: its a shortbed, single driveshaft. u joints feel solid, no play in those. I did some driveline measuring today & some things are off. here's what I found:
truck sits at a 3 degree rake (down in front) its lowered in front w/ 3" drop springs & 2.5" drop spindles (early classic) & 5" drop rear springs (early classic) engine tranny sits at a 0-1 degree up rear diff is at 0 degrees shocks sitting in stock mounts are at 45 degrees. I need to fab new brackets but have known this for a good while. how it sat with the old tires. rears were 285/50-18 current tires are 295/45-18 so a little shorter.
04-19-2013, 10:23 AM | #5 |
Check you u joints they may feel ok on the truck but remove the driveshaft and feel them see if they feel notchie or stiff as you move them. mite find a damaged one good luck.
05-03-2013, 09:40 AM | #6 |
If your diff is 0 degrees and your trans is 0-1 up, I would start by fixing this.
Read this and adjust acordingly. http://www2.dana.com/pdf/J3311-1-DSSP.pdf Replace ujoints and that should do it
05-07-2013, 10:04 PM | #7 |
Are your wheels properly balanced? I'd check that first... Amazing how much vibration goes away after you balance a set of tires.
1980 C10 SWB Yukon 5.3/5 speed 3.73 gears. |
