Old 02-03-2019, 08:28 PM   #876
COCONUTS
COCONUTS's Avatar
Re: What did you do to your truck today part IV
Originally Posted by studeclunker View Post
The Sway-Bar sounds interesting. I'm almost afraid to ask how much.
Well, ya made me look! Price seems reasonable. The installation image looks a lot like the sway bars on my Studebakers.
I had a Summit coupon code and paid $118 shipped for mine. That was a couple of months ago. I drove my truck yesterday and again today about 100 miles total. WHAT A DIFFERENCE! Easy install too.
COCONUTS is offline   Reply With Quote
Old 02-05-2019, 08:52 PM   #877
studeclunker
studeclunker's Avatar
Love your username, reminds me of the Marx brothers!
So, took the wanderlust out of your steering, did it?
studeclunker is offline   Reply With Quote
Old 02-05-2019, 10:56 PM   #878
COCONUTS
COCONUTS's Avatar
I recently replaced all my suspension and steering and had the truck aligned and it drove great. The sway bar made it better.
Old 02-08-2019, 10:32 AM   #879
1998c1500
1998c1500's Avatar
Made a drink holder that clips under my seat out of stainless network server rails. Any ideas on what the seat came from?
1965 C10
1967 Camaro
1998 C1500
1998c1500 is offline   Reply With Quote
Old 04-22-2019, 10:57 PM   #880
allchevy58
allchevy58's Avatar
Last couple of weekends installed 70HD rearend with 3.54 gears, rear sway bar and painted rear and front suspension. Looking for rear upper shock mounts so I can install shocks.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 05-14-2019, 09:40 AM   #881
roll_the_dice
roll_the_dice's Avatar
I got in new bulbs (LED) for the dash cluster and tested them ...now to finish everything else!
My Build Thread
Instagram #notaratrodnotashowtruck
roll_the_dice is offline   Reply With Quote
Old 05-25-2019, 11:18 PM   #882
forestb
forestb's Avatar
Installed 1 gauge battery cables and ground and also added a group strap that goes from the frame to where the battery ground connects to the engine block. I am hoping that this will help with my truck having a hard time starting up again right after I turn it off.
forestb is offline   Reply With Quote
Old 06-09-2019, 11:47 PM   #883
allchevy58
allchevy58's Avatar
Wife painted the hood and grill surround today.
Old 06-10-2019, 12:01 AM   #884
forestb
forestb's Avatar
I added another heavy duty ground strap on the driver side that goes from the block to the frame and a standard size one from the frame to the cab. I hope that will help me not get shocked when I push on the horn button. It seems to be starting better when hot sense I beefed up the electrical system. I still am planning on wrapping the starter motor in heat shielding just in case the problem is caused by heat soak.
Old 06-12-2019, 02:05 PM   #885
1998c1500
1998c1500's Avatar
Installed Eaton posi unit with a 3.42 gear to replace open differential with 3.08 gear
1965 C10
1967 Camaro
1998 C1500
Old 06-12-2019, 05:08 PM   #886
The Rocknrod
Too Cool For School
The Rocknrod's Avatar
Nice.
Master Chief, US Navy, Retired - He ain't no drag Papa's got a brand new bag
1964 C10 Step-side Short Bed - In Progress
2009 2500HD Duramax LTZ
1948 GMC Panel
1956 Big Window Stepside
1953 5 Window Chevy Stepside
New Seat Foam for Bench Seats?
The Rocknrod is online now   Reply With Quote
Old 06-12-2019, 06:56 PM   #887
studeclunker
I need a FB-type love button for that drink holder! Brilliant piece of fab work!
Wife does wonderful paint work!
All I did today is finally get my truck running again after two weeks of tinkering abound and trouble-shooting with the help of our Technical Forum! We're off and running again!
Old 07-02-2019, 03:47 PM   #888
jbgroby
jbgroby's Avatar
I had to stay home today while my DD was being serviced. While that was being done, I decided to cut in the bumper gaurd holes while I'm waiting for the painter to finish them. The factor OEM templet made the drilling easy. Once I got past the 1/8" hole, I used a step drill to cut up to 5/8". You will notice the placement of the Bumper gaurds on the GMC are set outside of the lettering vs. using the bumper mount bolts as Chevy does. This is because the bumper gaurds would have interfered with the lettering. I've been wanted to cut these holes for about a year and never got around to it.
jbgroby is offline   Reply With Quote
Old 07-03-2019, 12:59 AM   #889
allchevy58
allchevy58's Avatar
Got grill support, grill, bumper and misc. back on. Had the grill, bezels and bumper powder coated.
Old 07-03-2019, 10:06 AM   #890
The Rocknrod
Too Cool For School
That really looks good.
1948 GMC Panel
Old 07-05-2019, 11:30 PM   #891
allchevy58
allchevy58's Avatar
Thanks, got it finished, took it to cruise night at Summit Racing. Installed bumper stickers like the originals, a friend made them for me.
Old 07-06-2019, 11:38 AM   #892
forestb
forestb's Avatar
I installed my new gauges.
Old 07-06-2019, 02:04 PM   #893
Steeveedee
Steeveedee's Avatar
Thumbs up Re: What did you do to your truck today part IV
That's a nice clean setup!
'70 Chevy 3/4T Longhorn CST 400/400/3.54 Custom Camper
"Orange Acres"
Old 07-06-2019, 08:19 PM   #894
forestb
forestb's Avatar
Thanks. Today I installed my controller for my kicker audio stereo. A little less glamorous but much more important I took out my fuel filter and dirt fell out both sides. I could not replace it because I have to order it from Summit because it threads into AN fittings. So just sprayed some engine degreaser into it and blew it out with compressed air. I know thatís probably not the right thing to do but it helped the truck runs a lot better. I will order one and install it next weekend. I might also add a filter before the pump.
Copyright ©2000 - 2019, vBulletin Solutions Inc.
