Old 07-02-2019, 12:01 PM   #1
WyattTX
Location of brake Proportion valve: Does it matter?
I notice many aftermarket master cylinders have the P valve directly under the master cylinder. But most OE P valves are long distance away from the master cylinder (like near the front bumper, or the center of the frame). Why is this? Is there a benefit of the P valve being further from the master cylinder, or are manufacturers just being mean and making it difficult to reach for nothing?
WyattTX is offline   Reply With Quote
Old 07-02-2019, 01:22 PM   #2
sweetk30
selective wrench turner guy
sweetk30's Avatar
Re: Location of brake Proportion valve: Does it matter?
my mid 80's truck i swapped to disc / disc and used a adjustable rear bias aftermarket valve and its next to the master now since i replumbed the hard lines and no problems.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
sweetk30 is offline   Reply With Quote
Old 07-02-2019, 01:23 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The "valve" on these old trucks is merely a junction block and not a proportioning valve. Not sure if the block needs to be so close to the master cylinder. But a proportioning valve can be anywhere as long as it can control the amount of fluid to proportion the front and rear brakes accordingly.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-02-2019, 02:30 PM   #4
WyattTX
Interesting. I just remember replacing a P valve on an 82 Jeep CJ8 (front disc, rear drum). It was bolted in the worst possible place, IMO. It was inside the C channel frame under the vehicle. I figured AMC engineers put it there for a reason, but maybe they were just jerks, afterall.
Old 07-02-2019, 03:35 PM   #5
mongocanfly
.I've gottem mounted on front crossmember and at mc on different trucks...all it is is a junction/dividing point...doesn't matter where it is...I prefer it down low just from a visual standpoint...
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 07-03-2019, 07:33 PM   #6
The Rocknrod
Too Cool For School
The Rocknrod's Avatar
No if it's bled properly it is a hydraulic connection, so no problem with the distance.
Master Chief, US Navy, Retired - He ain't no drag Papa's got a brand new bag
1964 C10 Step-side Short Bed - In Progress
2009 2500HD Duramax LTZ
1948 GMC Panel
1956 Big Window Stepside
1953 5 Window Chevy Stepside
New Seat Foam for Bench Seats?
Old 07-12-2019, 10:33 AM   #7
D13
D13's Avatar
GM ran the single front line feeding the valve as far as possible before splitting for each front line. Least amount of tube = lowest cost. Uses the prop valve as a L/R front line splitter too, thus saving another T. Plus it allowed the same location for all the brake combinations including the hydroboost mess, which doesn't play well with prop valve on MC.
1987 C10 6.2 oil burner
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
77 1/2 ton 250, 3OTT, and hokey aftermarket AC SOLD!
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 07-14-2019, 06:46 AM   #8
WyattTX
Ah, so the bad location is just cost cutting. That makes sense. Thanks for the info, everyone.
Old 07-14-2019, 07:01 PM   #9
Dead Parrot
Had a 79 Camaro with the P-valve bolted to the MC-Booster assembly.
Dead Parrot is offline   Reply With Quote
Old 07-14-2019, 07:36 PM   #10
kipps
Originally Posted by D13 View Post
...Plus it allowed the same location for all the brake combinations including the hydroboost mess, which doesn't play well with prop valve on MC.
I assume you mean the physical interaction between the steering hoses and the P-valve? -- two objects trying to occupy the same space?
Or is there something else that I'm not getting here?
1987 V20 truck, with a 2010 LMG 5.3, and a sm465 tranny.
kipps is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
