Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 06-13-2019, 03:40 PM   #1
Starwood
Best Option to Hook Up aftermarket Horn?
Hey fellas -
Stupid questions v3.0:
The male connector for the 15A fuse on the box is loose as you can see in the pic below. Is it OK the use this loose pin as a power source for an aftermarket horn that is using a toggle switch relay - or avoid it all together?
I ask because when I did try this route, it worked fine for a while, then radio went out, then horn...basically my system DID NOT like it.
Simply put, what would be the best pin option to attached this hot wire to?
Here is a pic of the toggle relay under the dash.
Thanks in advance.
Starwood is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
