Old 06-14-2019, 08:23 PM   #1
rpmerf
rpmerf's Avatar
Early Quadrajet APT plug
How do you remove the APT plug on early (1973) Quadrajets? should I drill it and use a pick, or go at it with dremel tool?
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 06-14-2019, 08:33 PM   #2
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Early Quadrajet APT plug
I never had one of those to my knowledge but there is this info;
https://quadrajetpower.com/apt-plug/
'69 GMC C2500 Custom Camper, 8 1/2' bed (same as Chevy "Longhorn"), 350 ci. mild RV cam, NP 435 CR 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 06-14-2019, 09:11 PM   #3
geezer#99
geezer#99's Avatar
Easiest way is to drill a couple tiny holes beside the plug and lever it out.
I suppose with a Dremel you could clearance one side easily too.
You could find a lot of crud in there and the screw not working.
Old 06-17-2019, 08:14 AM   #4
rpmerf
rpmerf's Avatar
Thank you. That plug is for the later Quadrajets (75ish and up) with the APT at the top. Earlier ones have it under the fuel filter.
Thanks. Sounds good, pretty much attack it enough to pry it. I am half expecting the screw to be frozen up in there
1997 GMC Suburban
Old 07-03-2019, 12:23 PM   #5
rpmerf
rpmerf's Avatar
I got the plug out. It was easy. Hit it with a 1/8" drill bit and it pried right out. Screw is frozen. Even let it soak in PB, ATF, and Acetone. Maybe next time the engine is good and hot I will see if it moves.
1997 GMC Suburban
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
