Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 06-27-2019, 04:21 PM   #1
Bahn112
Weird light issue
Hi guys,
I just picked up a '70 LWB and i'm trying to get everything in order so I can drive the thing around.
I'm having a weird issue with my tail lights. Specifically my Drivers side tail light.
When the lights are off the brake light works perfect but as soon as I turn the running/headlight lights on and step on the brake pedal, it won't light up. The passenger side tail light works just fine.
Have any of you guys run into this problem?
Any suggestions?
Bahn112 is offline   Reply With Quote
Old 06-27-2019, 08:33 PM   #2
franken
Re: Weird light issue
I'd pull the light assembly out and check the ground. In fact it isn't a bad idea to check/fix grounds all the way back to the battery, since they're usually sketchy.
franken is offline   Reply With Quote
Old 06-27-2019, 11:10 PM   #3
Bahn112
It's my understanding that the light housing itself is the ground so I cleaned up where the assembly bolts into the bed and that didn't do anything.
I thought it was weird that it works perfectly fine as long as the running/head lights weren't on. When the lights are on the parking light will work but as soon as the brake pedal is depressed there is nothing.
Old 06-28-2019, 02:12 AM   #4
franken
K, funny symptoms say there's a ground issue.
Old 07-01-2019, 11:01 PM   #5
Bonestock3ott
Is it possible that the wrong bulb was put in it or maybe someone forced the correct bulb in the wrong way and the brake filament is lighting as the parking light and when the much dimmer parking light filament lights as the brake light you can not see it.
Bonestock3ott is offline   Reply With Quote
Old 07-01-2019, 11:03 PM   #6
Bonestock3ott
Another possibility is someone spliced a replacement socket pigtail and has the wires reversed
Old 07-01-2019, 11:13 PM   #7
Bahn112
I don't think this is the case as it works just fine as long as the parking light/headlights aren't on.
I did take it all apart and the I am ordering a new socket plug as the one that was currently on the truck looked a little hokey (definitely spliced a time or 2 by the PO).
Think it could be a bad headlight switch? Like it's routing the power incorrectly once the headlights/parking lights are turned on?
Old 07-01-2019, 11:24 PM   #8
Greenlee
I second what others have said. Sounds like a ground issue. I had some weird issues like this after I replaced the wood on my step-side bed. After pulling my hair out trying to figure out what was wrong, I put a ground strap from the bed to the frame and my lights have worked fine ever since then! I guess the new wood somehow interfered with the ground.
Greenlee is offline   Reply With Quote
Old 07-01-2019, 11:49 PM   #9
Bahn112
I'm definitely going to get a ground strap kit. I've been reading up on them and they seem like an easy way to make sure that all the circuits have a good ground to run to.
Any suggestions on one kit over another?
Old 07-05-2019, 10:58 AM   #10
Andy4639
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: Weird light issue
I would get the voltmeter out and test it for continuity. See what is going on. I will say it could be in the turn signal switch area. All wires run through it and when the brake pedal is pushed it directs the wiring on what to do out back. If it works with out the lights on but not when on a good chance is the head light switch.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 07-05-2019, 10:51 PM   #11
Bahn112
I'll be ordering a headlight switch when I place my next order with LMC. Hope that fixes it.
Old 07-07-2019, 06:46 PM   #12
Bahn112
Actually, the more I think about it it probably is not the headlight switch. The left/right split doesn't happen until the harness splits towards the rear of the truck. Since my passenger side works just fine and it's only the drivers side that is having issues I'm circling back to it being a ground problem.
Old 07-08-2019, 06:37 AM   #13
Hammered 77
Hammered 77's Avatar
If it's been spliced, try switching the wires. Ask me how I know!
Rick
Hammered 77 is offline   Reply With Quote
Old 07-08-2019, 06:47 AM   #14
rpmerf
rpmerf's Avatar
Sounds like a ground. When the tail lights are off, the power goes from the brake switch, to the brake filament, then it should go to the ground, but since that isn't available, it goes back through the running light filament and grounds through the headlight switch.
When you initially turn on running lights, the running lights are grounding through the brake pedal switch.
When both are providing power, there is no ground available, and the light turns off.
I'd be willing to bet the driver's side tail light is brighter than the passenger's light.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 07-09-2019, 10:39 PM   #15
Bahn112
In addition to getting some grounding straps, where are the ground locations for the taillights? I want to clean them all up back there to ensure as good a ground as possible.
Old 07-10-2019, 07:01 AM   #16
rpmerf
rpmerf's Avatar
I think it grounds where the backing plate bolts into the body
1997 GMC Suburban
Thread Tools
Display Modes
Copyright ©2000 - 2020, vBulletin Solutions Inc.
