Old 06-28-2019, 08:19 PM   #1
Backpayne
Question on c20 engine perch in '64
I'm installing a big block olds 455 and have a question about the engine perches.
The c10 perches are a tad too tall, which is expected and I will add a 1/4" spacer, but the frame bolt holes do not line up. Should I just drill new bolt holes in the frame OR should I notch the frame rail a little to get the holes to line up?
Pictures are of my situation.
Thanks!
Backpayne is offline   Reply With Quote
Old 06-28-2019, 11:38 PM   #2
Captainfab
60-66 Nut
Re: Question on c20 engine perch in '64
I would just trim the top flange of the frame back a little. You may have to do that anyway for exhaust manifold/header clearance.When big blocks became available in trucks in 1968, the top flange of the frames were narrower from the factory for exhaust manifold clearance.
Old 06-28-2019, 11:45 PM   #3
Backpayne
Thanks, Captain. I dropped the engine in with the mounts and perches attached. I'm going to add a " spacer and drill new holes. You are definitely right about the headers/exhaust manifolds and trimming the frame; it's an awfully tight fit.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
