Old 06-29-2019, 12:55 PM   #1
rvrfoot
1966 steering column
I have a 66 column. I want to know if I can put a 67 steering shaft in my 66 column. So I can put a newer steering wheel on?Name:  DSCN0871.jpg
rvrfoot is offline   Reply With Quote
Old 07-06-2019, 12:22 PM   #2
rvrfoot
Re: 1966 steering column
Well I went to cpp and talked to them.
Old 07-06-2019, 05:53 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
What did they say?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-07-2019, 02:50 PM   #4
rvrfoot
Wow only 179 people looked but no one has a answer? Hello Clyde 65 cpp said the new Budnik should work.
Old 07-07-2019, 05:01 PM   #5
bloo
What difference would a 67 shaft make to the steering wheel?
I once put a 68 or maybe 67 shaft in a 66 column, to make the 66 column have the right length and flange for a power steering box. This was a 4-speed column, no shifter.
I used the 66 steering wheel.
bloo is offline   Reply With Quote
Old 07-07-2019, 05:28 PM   #6
The Rocknrod
Too Cool For School
The Rocknrod's Avatar
Does Budnick make a steering wheel that doesn't use a 9 bolt adapter?
Master Chief, US Navy, Retired - He ain't no drag Papa's got a brand new bag
1964 C10 Step-side Short Bed - In Progress
2009 2500HD Duramax LTZ
1948 GMC Panel
1956 Big Window Stepside
1953 5 Window Chevy Stepside
New Seat Foam for Bench Seats?
Old 07-07-2019, 05:39 PM   #7
rvrfoot
No.
Old 07-07-2019, 05:44 PM   #8
rvrfoot
Because Budnik said the wheel adapter will work on a 67 to 94
Old 07-07-2019, 06:29 PM   #9
Clyde65
Clyde65's Avatar
I am not sure but if the shafts are the same diameter, it would be worth checking it out
Clyde65
Rebuild of Clyde
support our troops!
Old 07-07-2019, 08:52 PM   #10
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I'm the 277th viewer and I have no answer.
66 Service truck build:
Old 07-07-2019, 09:32 PM   #11
bloo
If there's some reason it wont go on there, it isn't the shaft. I did that shaft swap and put the 66 wheel back on. It fits and looks completely stock. It is just shorter on the steering box end.
Maybe it's the signal lights or the cancel mechanism or something like that?
Old 07-07-2019, 11:13 PM   #12
69 C10 LWB
I put a wheel from a 90 something in my 64. I didnít need any adapters or anything. It was a direct bolt in. Why do you think you need a different shaft?
69 C10 LWB is offline   Reply With Quote
Old 07-08-2019, 09:50 AM   #13
stsalvage
Scrapper 1
stsalvage's Avatar
the splines from 1960--72 are the same I used a smaller steering wheel from 1967 on my 1972 column and when I needed a steering wheel for my 1964 C60 bobtail I pulled a 1968 off and put it on no difference
stsalvage is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
