Old 07-01-2019, 08:41 PM   #1
Tonys1963
I need help! 454
Hello all and thanks in advance to those who respond. I have a 350 hp 454 in my 63 c10. It has been running great for the last year. I had it out last week and it started running rough kind of like it was loading up, missing etc. I found two spark plugs loose and a couple of plug wires were melted. I put in fresh plugs and put on some old wires i had that were good to replace the burnt ones unitl my new ones get here. now it is running alot better and will cruise smooth, if i accelerate hard it sputters and pops thru the carb. I went from enough power to break the tires loose at 15 mph to not enough power to break the tires loose at all. I really dont know where to start
Tonys1963 is offline   Reply With Quote
Old 07-01-2019, 11:26 PM   #2
Captainfab
60-66 Nut
Re: I need help! 454
Have you checked your timing lately? Are your rockers making noise? If so, your cam may be going flat.
Old 07-01-2019, 11:27 PM   #3
Tonys1963
John - no top end noise and the timing is at 18 degrees at idle
Old 07-01-2019, 11:58 PM   #4
geezer#99
geezer#99's Avatar
That would be 18 with the vac advance plugged off and checked at 700 rpm, correct!
Old 07-02-2019, 04:25 PM   #5
Tonys1963
That is with the idle set at 700 rpm and the vacuum hooked to the carb. This is where the engine has been set and has ran very well. Iím not getting any valve train noise and the idle is smooth.
Old 07-02-2019, 04:59 PM   #6
geezer#99
geezer#99's Avatar
So with that set up depending on how much advance the vac pot gives you then you likely have only a few degrees initial timing.
You might even be atdc.
You need to plug off the vac pot and set your initial correctly.
Try 12 degrees.
No initial is the reason you have no power and sputtering thru the carb.
Old 07-02-2019, 06:22 PM   #7
crazy longhorn
Fabricate till you "puke"
yes, as the other geezer said...12 initial....to 14 initial not to total more than 36 degrees, with the vac can unhooked/ plugged....shorthorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-02-2019, 08:51 PM   #8
Tonys1963
Geezer - I owe you a hand shake and a cold beverage of your choosing. I adjusted it and itís running great. What worries me is why it ran ok than suddenly changed, my distributor was tight.
Old 07-02-2019, 10:13 PM   #9
geezer#99
geezer#99's Avatar
Check the weights and springs in the distributor. They could have been stuck and loosened up or are stuck.
Also check the vac advance moves the plate easily.
Wierd things happen!
Old 07-06-2019, 10:37 PM   #10
74CustomK20
74CustomK20's Avatar
My old man had this problem on his 92 350. Screwed with the dizzy timing all that never made a difference. Come to find out another plug wire had shorted out and he had zero passing power.
Big Nate
Carp. Local 224. Buy made in the USA!
96 F250 Supercab 4x4 7.3
74CustomK20 is offline   Reply With Quote
Old 07-09-2019, 11:44 AM   #11
mattfranklin
mattfranklin's Avatar
Sometimes advancing the timing a little helps to make up for power lost due to other issues. Like a carb being not quite right. Advancing the timing on my old '84 S-10 made up for the flaky emissions carb that badly needed a rebuild, but I didn't have time or garage space or talent to do that. ;-)
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
