07-02-2019, 12:01 PM | #1 |
Location of brake Proportion valve: Does it matter?
I notice many aftermarket master cylinders have the P valve directly under the master cylinder. But most OE P valves are long distance away from the master cylinder (like near the front bumper, or the center of the frame). Why is this? Is there a benefit of the P valve being further from the master cylinder, or are manufacturers just being mean and making it difficult to reach for nothing?
07-02-2019, 01:22 PM | #2 |
Re: Location of brake Proportion valve: Does it matter?
my mid 80's truck i swapped to disc / disc and used a adjustable rear bias aftermarket valve and its next to the master now since i replumbed the hard lines and no problems.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
07-02-2019, 01:23 PM | #3 | ||
"I ain't nobody, dork."
The "valve" on these old trucks is merely a junction block and not a proportioning valve. Not sure if the block needs to be so close to the master cylinder. But a proportioning valve can be anywhere as long as it can control the amount of fluid to proportion the front and rear brakes accordingly.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
07-02-2019, 02:30 PM | #4 |
Interesting. I just remember replacing a P valve on an 82 Jeep CJ8 (front disc, rear drum). It was bolted in the worst possible place, IMO. It was inside the C channel frame under the vehicle. I figured AMC engineers put it there for a reason, but maybe they were just jerks, afterall.
07-02-2019, 03:35 PM | #5 |
Post Whore
.I've gottem mounted on front crossmember and at mc on different trucks...all it is is a junction/dividing point...doesn't matter where it is...I prefer it down low just from a visual standpoint...
07-03-2019, 07:33 PM | #6 |
Moderator
No if it's bled properly it is a hydraulic connection, so no problem with the distance.
07-12-2019, 10:33 AM | #7 |
GM ran the single front line feeding the valve as far as possible before splitting for each front line. Least amount of tube = lowest cost. Uses the prop valve as a L/R front line splitter too, thus saving another T. Plus it allowed the same location for all the brake combinations including the hydroboost mess, which doesn't play well with prop valve on MC.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
07-14-2019, 06:46 AM | #8 |
Ah, so the bad location is just cost cutting. That makes sense. Thanks for the info, everyone.
07-14-2019, 07:01 PM | #9 |
Had a 79 Camaro with the P-valve bolted to the MC-Booster assembly.
07-14-2019, 07:36 PM | #10 | |
Or is there something else that I'm not getting here?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
