Old 07-03-2019, 12:23 AM   #1
pilotXC
350 Zero Compression #3 and #5
My truck all of a sudden starting pining really bad under load or acceleration about 3-4 weeks ago and I thought it was bad gas, so drained the tanks and started with new gas, didn't help. Checked the timing, it was fine. Checked plugs, looked good. Checked the cap and rotor, all contact points were terrible, so I replaced and no change. Finally thought it was a carb problem, so rebuild the carb and found the primary side very dirty so thought for sure it was leaning out under load and it would be fixed, no change. Did a compression test at a local shop, #3 and #5 have zero compression. Temp is normal on the gauge and seems normal under the hood, oil pressure is good on the gauge (same as it's always been). The shop said it's not a head gasket and that there is a crack in the block between the cylinders, but that would show in water in the exhaust or in the crank case, or something somewhere? Haven't done a leak down test, but just curious if anyone has had any similar issues. Would zero compression create a knocking noise?
pilotXC is online now   Reply With Quote
Old 07-03-2019, 03:07 AM   #2
mongocanfly
Re: 350 Zero Compression #3 and #5
zero compression will cause all kinds of issues....you sure wont be able to do a leakdown test on 3&5...
if it has no compression sounds like the heads will be coming off at the least....could be bent valves or blown head gasket
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 07-03-2019, 07:07 AM   #3
PGSigns
PGSigns's Avatar
Well if it were a crack I would expect it to be a big one to kill the 2 cylinders and you would have water. I could easily be a head gasket between the two cylinders. If it has been a while it could have scorched the deck and the head surface. Heads need to come off to see what has gone south and make a plan on what to do from there.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 07-03-2019, 02:34 PM   #4
Dead Parrot
Possible the thermostat stuck shut or nearly so long enough to cause an overheat, the pinging and resulting loss of compression. Happened to my father many years ago on his way to work. Result was a cracked/blown head gasket between two cylinders. Didn't otherwise do much harm. Pulled the heads, had a valve job done since the heads were off anyway, replaced the gaskets and thermostat. Engine was good for many more years. It was long enough ago I don't remember what noises the motor was making before the repair.
If it did do a one time overheat, could have blown one of the exhaust gaskets in the process.
Dead Parrot is offline   Reply With Quote
Old 07-03-2019, 07:58 PM   #5
sweetk30
selective wrench turner guy
sweetk30's Avatar
make sure both have closed valves . push air in 1 and see if it comes out the other plug hole . if so popped head gasket or cracked head .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
sweetk30 is offline   Reply With Quote
Old 07-03-2019, 11:48 PM   #6
pilotXC
Thanks everyone... At the very least, looks like I'm pulling the head, but will try to do a leak down to see if I can find where the compression is going first.
Old 07-09-2019, 06:44 AM   #7
PGSigns
PGSigns's Avatar
If you have zero on the two cylinders a leak down is not going to tell you much more than the compression gauge. Just pull the head.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 07-09-2019, 01:18 PM   #8
mattfranklin
mattfranklin's Avatar
Sounds way more like a failed head gasket than a cracked block. Especially with the zero compression on adjacent cylinders.
Not sure how a shop could be so confident it was not a gasket issue given these obvious symptoms. Unless you have the lightweighted scalloped '624 heads and they are assuming the worst.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 07-09-2019, 01:26 PM   #9
pilotXC
When I picked it up they said, maybe it's a head gasket that's causing the compression problem, but that wouldn't fix the pinging/knocking sound. Haven't had time to dig into it more yet and not looking forward to finding a broken piston skirt or something, so have been kind of delaying the inevitable...
Old 07-09-2019, 03:56 PM   #10
mattfranklin
Good luck with it and let us know what you guy find.
Old 07-09-2019, 06:21 PM   #11
pilotXC
Thanks... I confirmed air between the 3 and 5 cylinders this afternoon. Just a matter of if it's a gasket issue, head issue, or block issue. Going to start by pulling the head and seeing what I can figure out from the top of the engine and go from there...
Old 07-09-2019, 06:32 PM   #12
geezer#99
geezer#99's Avatar
When you pull the head off could you take a pic of it. Just the valve side will do.
Old 07-09-2019, 07:08 PM   #13
sweetk30
sweetk30's Avatar
seen a few with popped gaskets between the cylinders . cleaned up surfaces and made sure all was good and smacked on new gasket SET since your all the way in there do both and they were good after the new gasket .
Old 07-12-2019, 03:45 PM   #14
HO455
HO455's Avatar
Good luck! Hoping for a bad gasket.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 07-18-2019, 08:34 PM   #15
pilotXC
Finally pulled the head today and sure enough, the gasket was gone between 3 and 5. Anyone have any thoughts on if this would cause a ping/knock under load?
Old 07-18-2019, 09:14 PM   #16
mongocanfly
Wow...you found it...I'd get the head checked for warpage while you got it off....
Mongo...aka Greg
Old 07-19-2019, 12:07 AM   #17
pilotXC
Suffice to say, I'm happy that's what it was... I haven't pulled the other head yet. Need to do some calling around for machine work/valve job and see if anyone will tell me if the head is indeed not warped, just to be sure as you said. I put a square up to it, and from what I can see with that, looks pretty straight, but I'm sure a machine shop can say for certain.
Also, from the top side, no sign of scoring or anything on the cylinder walls. Been told the noise was likely a broken piston skirt, cracked piston skirt, or wrist pin. Not sure if that would show from the top, I turned the engine over 2 rotations after taking the head off to check the walls. I know I'm trying to make this easier than it might be, but it seems like fuel being pushed back and forth from cylinders would create some havoc and noise of pre-detonation, exhaust pushed back and forth, compression being pushed into the intake? I'm just not sure what part of the stroke 5 is in when 3 is on compression and vice versa and what results that would have on the other cylinder?
Old 07-19-2019, 12:38 AM   #18
mongocanfly
Only way to know for sure about pistons is pull the oil pan...
Mongo...aka Greg
Old 07-19-2019, 07:30 AM   #19
cadillac_al
The stock steel shim gasket wouldn't do that. I don't know why people buy those thick gaskets unless they know the heads are warped.
76 Chevy K20
76 GMC K15
77 Chevy C10
cadillac_al is offline   Reply With Quote
Old 07-19-2019, 12:38 PM   #20
vince1
After getting the head checked for straightness I'd just put a gasket in and carry on. Probably the noise you heard was from air across the cylinders.
It looks like you have some ridge on the cylinder walls so a rebuild could be in its not too distant future.
vince1 is offline   Reply With Quote
Old 07-19-2019, 03:23 PM   #21
truck-kid
Hard to tell from pictures for sure but appears that gasket bore is to small for your bore size .Looks like it was hanging into the bore when compressed.
truck-kid is offline   Reply With Quote
Old 07-19-2019, 05:30 PM   #22
Dead Parrot
#3 is two before #5 in the firing order. Possible the fire from #3 was lighting #5 near enough to the start of the compression stroke on #5 that it was trying to compress a burning charge. If so, that would probably make interesting noises even with the lack of compression seal.
You are going to be doing an oil change anyway. Screen the oil for metal debris. Cut apart the filter and do the same. If that looks good, verify the heads are in good shape, install new gaskets and fire it up.
Old Yesterday, 01:36 PM   #23
pilotXC
Thanks for everyone's comments and help...
I was overly optimistic when I pulled the head and saw the gasket popped between the cylinders. I sent a picture to a friend and saw him the next day, he said, "did you look at these pictures?" Yes, of course. "Did you see this crack?" F$%&!!!!!
If you look closely behind the water mark on the picture of the block, there is a hairline crack between the 3 and 5 cylinder. Block is fubarred. Most likely that's why the head gasket went. I have not over-heated the engine, but I did have to get the radiator rebuilt about a year ago so it could have ran super hot from the previous owner at some point, or the low fluid for who knows how long before I had it could have over time just caused the crack? No idea. Needless to say, I'm very discouraged and disappointed and not sure what I'm going to do at this point.
Considering just throwing a head gasket on and put it back together and drive it until I can find the funds for something else. The block is screwed anyway, unless someone would be willing to sleeve it I suppose? But maybe the gasket will go immediately again and it will all be for not? I don't "need" the truck right away, so might just leave it and figure out what to do? Pretty big let down to say the least.
Old Yesterday, 01:43 PM   #24
sweetk30
sweetk30's Avatar
now you say it i see the crack . but it was skimmed over as thats right were STUPID photo bucket put there hosted watermark thing .
Old Yesterday, 01:43 PM   #25
mongocanfly
That sucks...!!....your friend must have good eyes...I couldn't see it on the small screen...put it up on big screen and zoomed in ...now I see it....
Mongo...aka Greg
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
